: In any case, there are exactly two things "wrong" with aircraft engines. The
: spark timing is fixed and the mixture control is in the hands of the pilot. : And you can't do anything about the first problem until you fix the second. The first is a compromise, but generally works really well for aircraft engines... they *do* run at a constant RPM all the time. The second isn't that big of a deal if the pilot is properly trained to use the mixture knob. Trouble is most aren't because of the great degree of OWT and misinformation out there on the subject. I would argue that the #1 biggest problem with aircraft engines is that they are still air-cooled. Removing the tremendous thermal stresses of having 450 degree CHT's make most of the "routine" aircraft engine problems go away. Stuck valves, cracked exhaust flanges and cylinder heads, ridiculous octane requirements (100 for 8.5:1?) due to the heat and low RPM, galled cylinders/pistons due to overheating, shock-cooling, and cold-starts, etc. Liquid cooling stabilizes everything, lets more power be made more efficiently with greater reliability. It doesn't even have to add too much weight. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
... : In any case, there are exactly two things "wrong" with aircraft engines. The : spark timing is fixed and the mixture control is in the hands of the pilot. : And you can't do anything about the first problem until you fix the second. The first is a compromise, but generally works really well for aircraft engines... they *do* run at a constant RPM all the time. The second isn't that big of a deal if the pilot is properly trained to use the mixture knob. Trouble is most aren't because of the great degree of OWT and misinformation out there on the subject. Except that the optimal spark timing is a strong function of the air fuel ratio. To get the full benifit of leaning, you need to change the spark. You can't optimize the spark for the mixture if you don't know what the mixture is. I would argue that the #1 biggest problem with aircraft engines is that they are still air-cooled. Liquid cooling has it's advantages. Removing the tremendous thermal stresses of having 450 degree CHT's make most of the "routine" aircraft engine problems go away. Stuck valves, cracked exhaust flanges and cylinder heads, ridiculous octane requirements (100 for 8.5:1?) Octane requirement is a stong function of spark timing... Of course, large, open combustion chambers with lower charge motion tend to require higher octane too. due to the heat and low RPM, galled cylinders/pistons due to overheating, shock-cooling, and cold-starts, etc. Liquid cooling stabilizes everything, lets more power be made more efficiently with greater reliability. It doesn't even have to add too much weight. Getting rid of points would be an improvement also. Solid state magneto's are not hard to make. -- Geoff the sea hawk at wow way d0t com remove spaces and make the obvious substitutions to reply by mail Spell checking is left as an excercise for the reader. |
Capt. Geoffrey Thorpe The Sea Hawk at wow way d0t com wrote:
: Except that the optimal spark timing is a strong function of the air fuel : ratio. To get the full benifit of leaning, you need to change the spark. You : can't optimize the spark for the mixture if you don't know what the mixture : is. Agreed. All I'm saying is that the for the aircraft application, the operating regime (cruise) is a very small window of operating conditions. If it can be optimized within that window, but made simultaneously safe to operate outside of it, that'd be enough. I haven't thought it through completely, so they may be mututally exclusive. : Octane requirement is a stong function of spark timing... : Of course, large, open combustion chambers with lower charge motion tend to : require higher octane too. Isn't it a stronger function of compression ratio and CHT, though? Timing will help manipulate the time at which the peak pressure occurs, but the detonation margin has very little to do with timing. : Getting rid of points would be an improvement also. Solid state magneto's : are not hard to make. Agreed. Points suck. Making them lightning-robust might take some thought, however... ![]() All of these things (solid-state "points," variable timing intelligently dependent on RPM and manifold pressure, etc) would be very difficult to accomplish mechanically to aviation robustness standards. Computers like FADEC would make it easier to implement, but still quite difficult to certify. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
20 Nov 2005 - Today's Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | November 20th 05 09:43 PM |
2005 ANNUAL PASCO SEMINARS, BANQUET AND AWARDS PRESENTATIONS | Marc Ramsey | Soaring | 0 | November 8th 05 02:36 AM |
Oshkosh 2005 Redux | Jay Honeck | Piloting | 17 | August 6th 05 07:14 AM |
Oshkosh 2005 Redux | Jay Honeck | Home Built | 13 | August 5th 05 04:35 AM |
Oshkosh 2005 Redux | Jay Honeck | Owning | 13 | August 5th 05 04:35 AM |
