SEL 'FIRM' landings
Old January 9th 06, 04:27 AM posted to rec.aviation.piloting
Default SEL 'FIRM' landings
Confession time & a learning moment -
Picture my then nearly new C172M on the ground at Philipsburg MT, with
a runway 16/34, and a strong hot wind from what seemed like WSW at
maybe 25 knots. We had been camping with another couple that had
driven from from Idaho Falls & was time to shift the vacation back to
IDF. We loaded all the gear and the two women into their truck & us
guys were to fly to IDF. Obviously a better decision would have been
to wait, but I reasoned that since we were light.........
What runway to use? Well it was downhill slightly to the south so I
chose that one.
For some stupid reason (thinking a short/soft field situation because
of the elevation and the heat?) I tried to raise the nosewheel early in
the takeoff roll while using full right aileron. Things quickly
deteriorated into the rubbity-scrubbities as the gear protested being
dragged sidewise. Acceleration was slow, and it seemed like an
eternity to get to flying speed. Once horsed into the air, we cleared
the barb wire by a couple of feet.
It was pure chance that I took the crosswind from the right. Had it
been on the left, I'm sure we would have rolled it into a ball. My X/W
technique was awful & it took the next biennial to straighten that out.
Lessons:
1) In any choice situation, take the crosswind from the right. Be
especially wary of left crosswinds. (I have not seen this published
anywhere)
2) Recognize that in any marginal short field/soft field situation,
the presence of a crosswind takes precedence over everything else.
3) Plan your takeoffs. It is too late to start planning them once
initiated.
Old January 9th 06, 02:37 PM posted to rec.aviation.piloting
anywhere)
Can you expand on that a bit, please? I'm not sure I see where you're going
with this.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old January 9th 06, 04:26 PM posted to rec.aviation.piloting
anywhere)
with this.
When the nose is high in the flare, if you have to add power for any reason,
P-factor will tend to add to your problems with a wind from the left and help
you with a wind from the right. In addition, I've always found that slipping
into a wind from the right gives me better visibility in the high-wing aircraft
I've owned.
George Patterson
Coffee is only a way of stealing time that should by rights belong to
your slightly older self.
Old January 9th 06, 08:07 PM posted to rec.aviation.piloting
anywhere)
I should have clarified the sentence & said for takeoffs only. It
already takes right rudder in a zero wind to compensate for the
rotating slipstream etc, but it takes still more right rudder for any
left crosswind. The result for me (C172M) is that a 10 knot left
crosswind is like a 20 knot right crosswind in terms of rudder-needs
and pucker factor.
Is this true in the Cherokees? It may not be so much so because of the
fixed nosewheel steer connection, although when the nose is raised it
has to be true.
NRP
Old January 9th 06, 10:09 PM posted to rec.aviation.piloting
and pucker factor.
I'm still not sure I follow you. If your objective immediately after
takeoff was to have the fuselage aligned with the runway, as it is
immediately before landing, I'd agree that more rudder would be
required against the rudder weathervaning. Takeoff is not the same as
landing in this respect though. Upon liftoff you should make a
_coordinated_ turn into the wind in order to add the appropriate amount
of crab angle required to stay above the runway (left aileron and left
rudder into a left crosswind). Asymmetric rudder usage shouldn't
really apply, I think, aside from the usual net left-turning
tendencies.
If you're not flying in a coordinated manner on takeoff you're throwing
away performance and operating at less than optimal efficiency - at a
time when you can use all the performance you can get.
Or maybe I'm misunderstanding. I'm still licensed to learn.
-R
Old January 10th 06, 01:30 PM posted to rec.aviation.piloting
Makes sense to me!
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old January 10th 06, 04:56 PM posted to rec.aviation.piloting
tendencies.
This was intended for takeoffs only and has nothing to do with
post-lift-off handling. It is the amount of rudder required to
maintain directional control during the takeoff acceleration.
I use full aileron at the start & come off it during the roll. I find
that it requires rudder inputs to counteract both torque (actually it
is mostly spinning slipstream) effects and weathervaning due to the
crosswind. Sometimes the inputs have to add (such as a left crosswind)
, and sometimes they cancel (right crosswind).
I try to leave the runway in a near minimum airspeed and tire scrub
condition. Climbout etc is coordinated (I hope!)
A new direction for an old thread: Crosswind landings [email protected] Soaring 96 March 4th 05 01:22 AM
Rough Field Landings [email protected] Piloting 38 December 19th 04 01:42 PM
Precision Landings and practice [email protected] Piloting 34 December 17th 04 02:08 PM
Night landings vs. day landings Gerald Sylvester Piloting 15 February 12th 04 06:38 AM
