I was told ground runs is one of the worst things you can do to an airplane
engine, as it was designed for sustained high RPM operations, not ground run RPMS. You know, I've heard that since Day One of ownership, too, but ya just gotta wonder if it's not yet another "old wive's tale", like so many of these "tried and true" things. How does the engine know the difference between ground runs at, say 2000 RPM (run-up speed on our plane) and an extended descent? Is *that* "bad" for the engine, too? Doesn't running it for 30 minutes on the ground circulate the oil, and prevent corrosion? Can't you get oil temps up to 150 or better (I know, 180 is optimal, but...) with a ground run? Isn't that better than letting it sit and rot till spring? I fly too often for this to really matter, but I always wonder if it's a real issue or not? Kinda like "shock cooling" and "pulling the prop through" before starting on a cold day... And Marvel Mystery oil, while we're at it... :-) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
In article .com,
"Jay Honeck" wrote: I was told ground runs is one of the worst things you can do to an airplane engine, as it was designed for sustained high RPM operations, not ground run RPMS. You know, I've heard that since Day One of ownership, too, but ya just gotta wonder if it's not yet another "old wive's tale", like so many of these "tried and true" things. How does the engine know the difference between ground runs at, say 2000 RPM (run-up speed on our plane) and an extended descent? Is *that* "bad" for the engine, too? consider the difference in cooling air. -- Bob Noel New NHL? what a joke |
Ground running does not scavenge the vapors since the vent
system depends on airspeed. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Jay Honeck" wrote in message oups.com... | I was told ground runs is one of the worst things you can do to an airplane | engine, as it was designed for sustained high RPM operations, not ground | run RPMS. | | You know, I've heard that since Day One of ownership, too, but ya just | gotta wonder if it's not yet another "old wive's tale", like so many of | these "tried and true" things. How does the engine know the | difference between ground runs at, say 2000 RPM (run-up speed on our | plane) and an extended descent? Is *that* "bad" for the engine, too? | | Doesn't running it for 30 minutes on the ground circulate the oil, and | prevent corrosion? Can't you get oil temps up to 150 or better (I | know, 180 is optimal, but...) with a ground run? Isn't that better | than letting it sit and rot till spring? | | I fly too often for this to really matter, but I always wonder if it's | a real issue or not? Kinda like "shock cooling" and "pulling the prop | through" before starting on a cold day... And Marvel Mystery oil, | while we're at it... | | :-) | -- | Jay Honeck | Iowa City, IA | Pathfinder N56993 | www.AlexisParkInn.com | "Your Aviation Destination" | |
Jay Honeck wrote:
You know, I've heard that since Day One of ownership, too, but ya just gotta wonder if it's not yet another "old wive's tale", like so many of these "tried and true" things. How does the engine know the difference between ground runs at, say 2000 RPM (run-up speed on our plane) and an extended descent? Is *that* "bad" for the engine, too? I've wondered that myself. The only big difference that I can think of is that the circulation of cooling air will be different. As far as long descents is concerned, I've seen statements that this is harmful due to excessive cooling and possible plug fouling. Never seen a claim that oil circulation suffers, though. Doesn't running it for 30 minutes on the ground circulate the oil, and prevent corrosion? Can't you get oil temps up to 150 or better (I know, 180 is optimal, but...) with a ground run? Isn't that better than letting it sit and rot till spring? As several others have pointed out, circulation of the oil isn't the problem with the cam lobes. Those are lubricated by splash from the crank. I've never seen any claims that this differs much from splash while in flight, though. What I've read is that you really can't get the oil temperature high enough by running it on the ground. The claim is that ground running adds water and acids to the oil (flying also does this) and never gets the oil hot enough to vaporize these. Crankcase ventilation through the breather is also very poor on the ground; as a result, vapors that do form never leave the crankcase. As another poster suggested, some form of positive crankcase ventilation would probably help that. If the only real issue proves to be the buildup of pollutants in the oil from ground running, then changing the oil after every other run would take care of the problem; however, given a choice between this and simply flying the plane for a few hours, I'd be in the air. George Patterson Coffee is only a way of stealing time that should by rights belong to your slightly older self. |
On Mon, 09 Jan 2006 16:10:22 GMT, George Patterson
wrote: As several others have pointed out, circulation of the oil isn't the problem with the cam lobes. Those are lubricated by splash from the crank. I've never seen any claims that this differs much from splash while in flight, though. I actually thought this was a joke when I read it in a previous post. You mean to tell me that the cam REALLY gets it's lubrication from splash? The crankshaft has to whip it's throws into the oil in the oil pan so that the oil gets whipped around inside the engine and THAT's how the cam gets oiled? Lordy, thought that technology went out with Model T's I can't think of a single engine in the automotive world that depends on splash oil to lubricate anything. No wonder auto oil is not supposed to be used in airplane engines. Corky Scott |
On Wed, 18 Jan 2006 13:40:21 -0600, Mitty wrote:
In pushrod motors the rocker arm noses running against the valve stems are splash oiled. Also the timing chain(s), the distributor drive gear, ... Pretty much it is only the bearings that are pressure oiled. i.e., mains, rods, cam(s). The engines pushrod engines I've assembled had hollow pushrods and fed pressurized oil to the rocker arms. The rocker arms were hollow and injected oil onto the valve stem to assist in cooling. Yes, the top of the valve stem did not have any direct injection so it did require splash oil for it's lubrication. That's where roller rockers help. Guess I hadn't thought that much about it for a long while. I stopped working as an auto mechanic a long time ago. Corky Scott |
difference between ground runs at, say 2000 RPM (run-up speed on our plane) and an extended descent? Is *that* "bad" for the engine, too? I'm guessing, but in an extended descent, the engine was already running full bore for a while and is nice and hot and happy. In a ground run, the engine probably started out cold and never got hot and happy. Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
Nasa Icing courses | Jim Burns | Piloting | 96 | February 1st 06 04:16 AM |
ASRS/ASAP reporting systems - how confidential? | Tim Epstein | Piloting | 7 | August 4th 05 05:20 PM |
NASA Icing Course | [email protected] | Piloting | 3 | December 28th 04 05:18 PM |
About Acellerated Courses for Private | Dudley Henriques | Piloting | 137 | July 22nd 04 04:21 AM |
FAA letter on flight into known icing | C J Campbell | Instrument Flight Rules | 78 | December 22nd 03 07:44 PM |
