winglets
Old January 8th 06, 09:51 AM posted to rec.aviation.soaring
Default winglets
Ken Kochanski (KK) schreef:
"The rest is generated by lower pressure on the upper side."
hmmmm ...
http://www.eskimo.com/%7Ebillb/wing/airfoil.html
http://www.aa.washington.edu/faculty/eberhardt/lift.htm
Erik Braun wrote:
Hi Wayne,
yet the majority (?) of our lift is generated from the
HIGH pressure BELOW the wing.
No, it only generates 1/3 of the lift. The rest is generated by lower
I recommend you read
http://www.soaridaho.com/Schreder/Te...lets/Masak.htm
which explains the design and function of winglets.
Greetings, Erik.
True.
But I`m teaching aerodynamics in my club and it is extremely hard to
explain this to people. I don`t want to confuse people with vorticity
fields so the explanation "pushing air down will result in an
underpressure on top and an overpressure on the lower side of the wing;
that`s lift" seems to be sufficient for the understanding of lift as
far as gliding is concerned.
http://www.navier-stokes.net/
Not too smart to post when you`re just woken up. For those who wanna
know why, just take a look at my last post ;-)
Jarno Nieuwenhuize.
The Netherlands
LS4 Winglets Sleigh Soaring 2 June 8th 05 01:38 AM
Ventus A 16.6 extensions wanted or 15 meter winglets goneill Soaring 0 January 5th 05 06:27 AM
winglets for LS-1 Brad Soaring 4 October 26th 04 06:11 PM
ASW20L extentions with winglets? goneill Soaring 6 September 17th 04 10:28 PM
Discus Winglets Kevin Neave Soaring 2 October 15th 03 11:35 AM
