Lancaster California: Another Fatal Cirrus Crash
Old January 11th 06, 06:23 AM posted to rec.aviation.piloting
Default Lancaster California: Another Fatal Cirrus Crash
1. From the local TV news, the plane's engine quited when it turned
crosswind. It immediately dove down to the ground after engine quit.
2. Prior to the crash, it's done many touch and go on the William Fox
Field (KWJF).
3. Note that the temporature here in Southern California was over 76
degree in downtown LA. I would guess it must be close to high 80 or
even 90s in the desert. (The crash happend on 1:40PM)
4. From the TV news, local sheriff saw the chute ejected after it hit
the ground. But can't be determined by official yet.
5. The plane was a rental at VNY Gene Hudson Aviation.
My friend's SR22 had experienced engine quit last summer when he took
off from Las Vegas in a hot day, with fully loaded, with air-condition
turned on. It was caused by engine vapor lock. Fortuntely he ws high
and was close to JEAN ( 0L7). He made a successful dead stick landing
at JEAN. His wife on the side sreamed ...pull the chute..pull the
chute...but he did not attempted.
Old January 11th 06, 01:44 PM posted to rec.aviation.piloting
On 10 Jan 2006 22:23:21 -0800, "cpu" wrote in
. com::
Perhaps that story is available on their web-site. Can you provide
the TV station's web address?
the plane's engine quited when it turned crosswind. It immediately
That observation would be consistent with a stall/spin.
Field (KWJF).
Wouldn't turning the fuel pump on be expected to clear the vapor lock?
Old January 11th 06, 02:09 PM posted to rec.aviation.piloting
Interestingly, many of the local A&P comments in response to the 2002 fatal
crash of a Cirrus north of Syracuse, NY, suggested that these high
performance engines were not designed for repeated full power/low power
settings, as what happens over numerous touch and gos or, in the case of
the 2002 crash, repeated stall practice.
Peter
Old January 11th 06, 03:46 PM posted to rec.aviation.piloting
That was my first thought, since they are the only ones I know of that train
in Cirrus around here, but that plane was not their tail #.
As far as I know they only have 1 SR20 for rent, and it's a different tail
It was a windy day in S. Ca., which tells me the gusts were really high
around Fox (normal cenario), but news reports said wind was calm.
I have never seen a windy day in S. Ca. where it wasn't even windier at Fox.
I have been hit by gusts in that pattern that really made me pucker up.
I'm sure we'll be hearing more about it.
Alex
Old January 11th 06, 04:35 PM posted to rec.aviation.piloting
They've removed the crashed aircraft, quickly. You can still see the
cached version in Google by typing N526CD and click their cached
version web content.
Old January 12th 06, 03:15 AM posted to rec.aviation.piloting
That's tragic. Hitting a little close to home for me. I'll bet I met the
instructor at the last Cirrus demo in Van Nuys. I noticed only one other
instructor on the web site now too, so yeah, they removed her name already.
That's if it is who I think it is.
The local news will probably release the names in the next couple days.
Alex
"cpu" wrote in message
Old January 12th 06, 03:44 AM posted to rec.aviation.piloting
It's not, she is alive and well, checked in on a message board right
away.
It was a male instructor I am told. (not Gene Hudson)
The student is a husband and a father of a small child.
My friend called his wife the same night and found out it was him.
It tears your heart out.
We all don't know what happened, and we may never know.
You can just barely understand how the family must feel. This was
supposed to be the best and newest and the safest. Spared no expense.
And then this.
Old January 12th 06, 05:17 AM posted to rec.aviation.piloting
It's hard to hear one close to home. There were familiar faces in my
home field, the next day they were gone (hit the radio tower near
airport, night VFR went terribly wrong....etc.)
Been attended one of the FAA Wings seminar at Gene's school. One of
the best ones. My heart and thoughts go to the families and love ones
of deceased. RIP
Old January 11th 06, 05:17 PM posted to rec.aviation.piloting
On Wed, 11 Jan 2006 07:46:42 -0800, "#1ACGuy"
wrote in ::
http://www.genehudson.com/ghft/ac4rent.html
Aircraft Rental
We offer the following aircraft for rental: 2003 Cirrus SR22 N224PR
2005 Cirrus SR20 N526CD
2005 Cirrus SR20 N64CD
1978 Cessna T210 N44HR
2005 Cirrus SR20 Rate: $200/hr
Registration No: N562CD
Serial No.: 1545
General:
Factory NEW as of August 26, 2005
Fuselage, wings, stabilizers: Oven-cured pre-preg composite
Control surfaces: aluminum
Seats: 4
Power control: Single lever controls both throttle and propeller
Emergency Safety System: BRS CAPS (Cirrus Airplane Parachute System)
Secondary Safety System: Front Seat Belt Airbags
Buses: Dual redundant, with emergency cross-over capability
Alternators: Dual, 60amp/20amp
Batteries: Dual, independent
Engine:
TCM IO-360-ES
200 h.p. @ 2700 rpm
3-blade ‘Scimitar’ constant-speed propeller
Avionics:
Primary Flight Display (PFD):
Avidyne Entegra
10.4 full-color
All solid-state (MMIC) attitude and heading reference (AHARS)
Integrated air data computer, with continuous display of wind
direction and velocity; indicated airspeed, true airspeed and
groundspeed
Magnetometer: full-time, all-attitude sensing of magnetic north
Attitude, altitude and vertical speed displays
Trend indicators for airspeed and altitude
Heading, navigation (3 separate nav sources displayed simultaneously)
Heading, altitude and vertical speed 'bugs', interfaced to autopilot
Autopilot mode annunciators
Projected track indicator
Multi-Function Display (MFD)
Avidyne FlightMax EX5000C
10.4" full-color color moving map
Flight plan with color-coded active and next legs
Airports, navaids, intersections and obstacles database
Enhanced Ground Proximity Warning [TAWS/EGPWS] w/audio alerts
L3 Stormscope lightning detection system
Satellite-based in-flight XM weather including METARs, uplinked
weather radar
Fuel management (fuel flow, fuel on board, fuel predicted remaining at
destination)
Engine management: Engine parameters, temperatures; lean assist
Backup instruments: airspeed, altitude and attitude indicators
Navigation: Dual Garmin GNS430 GPS/VOR/LOC/GS receivers,
IFR certified Autopilot: S-Tec System 55X Two axis
Completely separate from PFD/attitude indicators; acts as a backup to
flight instrument failure
Heading, Nav, GPSS, and Approach modes interfaced to PFD
Vertical speed hold, altitude pre-select, altitude hold, glideslope
coupling
Audio Panel: Garmin GMA340
Built-in four-place intercom with pilot/crew isolation
Auxiliary jack for entertainment system input
Marker beacon receiver with mute
Optional Equipment:
Rosen Sun Visors
Rental:
High Performance Glass Cockpit Trainer
Available for dual or solo
Student Pilot or better
Cirrus Transition Course (taught by us) or 10 hours make/model plus
checkout
Online Scheduling
Aircraft Checkout Questions (PDF File)
Tel: 818-382-4791
7949 Woodley Ave
Van Nuys, California 914
Old March 31st 06, 09:34 AM posted to rec.aviation.piloting
Engine quitting does not normally cause an airplane to dive to the
ground but pilot screwing pooch does.
As Larry said, sounds like stall spin.
www.rogerhalstead.com
Field (KWJF).
Cirrus SR20 Fatal Crash in SC Richard Kaplan Piloting 24 April 22nd 04 10:47 AM
