![]() "Montblack" wrote what's best - shaving or painting? How far out from the hub for each method? ...assuming a wooden prop. Just curious. The further out, the less weight needs to be added. I have read that it is far better to not disturb the seal of the prop by shaving, if at all possible. It may not be possible to change a badly off prop with paint alone. Others have opinions reflecting far more experience than me. The largest prop I have ever balanced is 22 inches, but it does make a huge difference. -- Jim in NC -- Jim in NC |
A machinist friend of mine made an incredible prop balance checker for
me. It consists of a 6" long metal tube connected to a 4" diameter, 1/8" thick disc that has another disc, 1/2" thick attached to it. The smaller disc is of the diameter that fits snuggly into the bottom of the prop, and the larger disc butts against the bottom of the prop. A 1" diameter x 1" long fitting is turned on a lathe, and bored 3/4" ID to within 1/4" of the end, and another bore follows of 5/8" ID to within 1/8" of the end. This 1/8" closed end is drilled in the center about .02", and then sliced/turned off. This creates a 1" dia x 1/8" thick disc that is concentric with the fitting. A second 1/2" long fitting is made that fits snuggly inside the 1" tube and also has a ..02" hole drilled through it. The tube with the attached discs is inserted into the back of the prop. A thin piece of cable is threaded through the disc and first fitting, then the second fitting then down through the 6" tube and the cable secured on the bottom discs. The second fitting is pushed down into the 6" tube until it is just above the fore-aft center of the prop, then the first fitting and its disc is placed over the top end of the tube. Now the cable is used to suspend the prop. The turned-off disc on the top of the first fitting acts as an indicator of out-of-balance of the suspended prop. If the prop is balanced, the turned-off disc will be concentric with the fitting just under it. Any out-of-balance will cause the disc indicator to be off-center. The fitting inside the tube, which holds the cable in the long tube's center, adjusts the sensitivity. When it is above the prop's fore-aft CG, the sensitivity is low. Pushing it further and further down into the tube toward this CG, the sensitivity gets greater and greater, until when it is below the CG, the prop flops over to one side. When adjusted for good sensitivity, it will show the unbalance of a #4 washer at the tip of a 63" diameter prop. The indicator disc has its maximum deflection in the direction opposite from the unbalance. It shows unbalance in all directions. Try it; you'll like it! Paul |
![]() "ELIPPSE" wrote A machinist friend of mine made an incredible prop balance checker for me. That is a keeper! Thanks. -- Jim in NC |
I'm going to write an article for Contact! magazine describing how to
build one of these balancers with included drawings (one word is worth a thousand pictures, or something like that!). I just used mine today to balance my three-blade which I recently painted one blade white, one red, and one blue! I balanced it by spraying on more paint front and back on the lighter blades. It's nice to be able to spray away your unbalance! The balancer is so sensitive you can watch the balance slightly shift as the paint dries! |
Wierd vibration -- Prop or engine, balance or not??? | Chuck | Owning | 17 | December 1st 04 02:12 PM |
Propeller for aircraft engine ground test | Guy Deraspe | Home Built | 0 | July 21st 04 04:41 AM |
F4U inverted gull wings | Bob M. | Military Aviation | 52 | July 16th 04 02:11 PM |
Sensenich W72CK-42 propeller for sale | Steven P. McNicoll | Owning | 0 | November 18th 03 03:03 AM |
Sensenich W72CK-42 propeller for sale | Steven P. McNicoll | Aviation Marketplace | 0 | November 18th 03 03:02 AM |
