Real time continuous Prop balancing
Old January 11th 06, 03:12 PM posted to rec.aviation.homebuilt
Default Real time continuous Prop balancing
abripl wrote:
This thread is not about how to balance a prop or shop balancing
machines.
Did anyone use BalanceMasters device bolted on their ultralight prop?
These devices apparently balance the prop continuously as you fly.
Similar devices are used on truck wheels - see www.BalanceMasters.com
and www.centramatic.com
Which raises the question if the prop is correctly balanced in the first
place why would you need dynamic balancing in an aircraft? It would seem
to me G forces would throw it off anyway.
Dan, U.S. Air Force, retired
Old January 11th 06, 04:54 PM posted to rec.aviation.homebuilt
In article Je9xf.78660$sg5.27262@dukeread12,
"Dan, U.S. Air Force, retired" wrote:
machines.
Maybe because balance changes with prop speed? I don't know anything
about the specific unit in question, but, in theory, an onboard real
time continuous balancer seems useful - at least for the fixed pitch
crowd.
Old January 11th 06, 05:11 PM posted to rec.aviation.homebuilt
I recently spent $250 for prop balance and it did not work. It was
still about .2 ips out. A factory prop is usually fairly close and all
it needs is a few grams to correct it.
Such a continuous balance device would also take care of imbalance as
the prop gets nicks and scratches. It might even help in flight with
accidental prop damage. These are some of the good reasons...
Old January 13th 06, 03:03 PM posted to rec.aviation.homebuilt
Not to mention this could well be a solution in search of a problem.
When it comes to RELIABLE flying...
- KISS -
K eep
I t
S imple
S toopid.
- Barnyard BOb - more than a half century of flight
Real Time to build an RV10 [email protected] Home Built 13 October 31st 05 02:20 AM
Prop balancing and assorted observations - long Dave Hyde Home Built 10 June 27th 04 01:08 AM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
