How long to keep VOR check records?
Old April 9th 04, 02:08 PM
Andrew Sarangan
An approach is where a VOR accuracy really matters. If you are off by a
few degrees during enroute, the worst that can happen is an annoyed
controller. During approach the outcome may be a lot worse. Would you fly
a VOR approach to minimum if you are not sure if the VOR has not been
checked?
"Dan Thompson" wrote in
m:
I bet you are right. Since it is not possible to fly under IFR below
1000 AGL, except taking off or on an approach, what difference does
that make?
"Andrew Sarangan" wrote in message
. 158...
. com:
Well, since practically everybody uses GPS, and radar coverage is
essentially nationwide now, making sure your VOR is accurate within
a couple of degrees every 30 days, and also keeping a detailed
record of that, seems a bit out of date. Kind of like making sure
your buggy whip is in good condition every 30 days.
Radar coverage does not extend nationwide at low altitudes. In fact I
would
bet that 99% of the country does not have radar coverage below 1000'
AGL. This is where VOR accuracy really matters anyway.
Ultralight Club Bylaws - Warning Long Post MrHabilis Home Built 0 June 11th 04 05:07 PM
Flight test update - long nauga Home Built 1 June 5th 04 03:09 AM
SWRFI Pirep.. (long) Dave S Home Built 20 May 21st 04 03:02 PM
Simpy One of Many Stories of a Time Not So Long Ago Badwater Bill Home Built 40 March 16th 04 06:35 PM
IFR Long X/C and the Specter of Expectations David B. Cole Instrument Flight Rules 0 February 24th 04 07:51 PM
