Carb Rebuild -- Suggestions for where to go
Old January 12th 06, 02:36 AM posted to rec.aviation.owning
Default Carb Rebuild -- Suggestions for where to go
Does it leak gas when "flooding"? Or does it just go too rich. One
possibility is you have a float with a leak in it. This will make the
carb run rich and even leak due to overflow. Just an idea.
Just get a mechanic and have him take it apart. There is some FAA
thing, but if you send it out for overhaul, theres no biggie. He can
take it apart, just cant put it back together. Some mechanics can put
them back together though. I dunno, all that FAA stuff but there is an
issue there. Some mechanics work on carbs and some don't. Find one that
will. Have him take the bottom off the carb, check the workings out,
find out whats wrong and fix it. Ask around.
I know what you mean about wanting to find the problem. That way you
make sure it gets fixed. Otherwise its just some kid in a shop who
could care less.
Old January 12th 06, 01:48 PM posted to rec.aviation.owning
Go here for best prices: www.aircraftspruce.com.
Old January 14th 06, 01:56 AM posted to rec.aviation.owning
On 11 Jan 2006 18:36:21 -0800, "Doug"
could care less.
When I got it back on the ground and looked, gas was running out of it
like crazy! Fuel pressure went up to about 10psi with the electric
pump on and normal is around 6+. I didn't have a flashlight, but it
looked like it was running out of both the main jet and the
accelerator jet when the fuel pump was turned on.
Short version of my mechanic situation: The guy I've worked with for
15 years died in July. He could fix anything, and I have no doubt I'd
have already learned the cause if he was still around. I do have a
mechanic (who was with me when it quit), but he mostly does
restorations, not repair. We took it apart and the float seemed fine.
I will check that out further though by submersion. Our thoughts are
that something either caused the float to hang up, or something is
going on in one of the chambers we can't analyze. I don't know how
the accelerator pump works well enough to know if something goes wrong
with it if fuel could flow through easily causing this flooding
condition.
Thanks for your reply, and all others who have responded. I'm open to
comments from anyone who may have good knowledge about this situation.
z
Old January 14th 06, 04:30 AM posted to rec.aviation.owning
could care less.
6 to 10 psi on a MA 4-5? 6 psi is the test pressure to check for leaks;
operating pressure is 3-5 psi. No wonder the fuel was running out the
bowl!
condition.
z
Remve "_" from email to reply to me personally.
Old January 14th 06, 01:47 PM posted to rec.aviation.owning
Typical problem here is the float valve. It becomes flattened on the
cone surface. Replace the float valve and it will be OK. May need to
adjust the float height also.
Old January 15th 06, 01:26 AM posted to rec.aviation.owning
If you/your mechanic do decide to look at float level, first make a
fixture to show the operating float level.
Drill a small hole thru a 1/8 inch dia NPT pipe plug, and epoxy a 1 ft
length of clear flex tubing (such as model airplane fuel line) into the
hole.
There is a 1/8 inch (I think) NPT pipe plug on the back of the carb
that is ported into the bowl. Remove this plug & screw the fixture
plug into this port. Hold the tubing up to see where the float level
actually settles - and decide from there.
Old January 15th 06, 02:17 AM posted to rec.aviation.owning
standpipe
hole.
that is ported into the bowl. Remove this plug & screw the standpipe
fixture
actually settles - and decide your next course of action from there.
Obviously this fixture is for ground testing only.
FWIW - A fellow I know with a 182 had a similar carb rebuilt & had
quite an ongoing runaround with the certified repair station that did
it. There is a seal on the throttle shaft that if omitted or damaged,
ports intake manifold vacuum to the float bowl area. He was having
trouble with excessively lean mixture. I know this is not your problem
- but just be forwarned that a CRS doesn't necessarily get things right
either.
Reply
Have you ever experienced carb ice with an injector carb? flybynightkarmarepair Home Built 1 January 31st 05 01:48 AM
Induction System Water Problem Mike Spera Owning 1 January 30th 05 05:29 AM
Use of Carb Heat John Kirksey Piloting 4 November 30th 04 07:26 PM
Carb Temperature Gauge fly_the_skies Home Built 6 January 14th 04 03:32 PM
Full before landing checklist in the pattern? Tony Roberts Piloting 70 November 15th 03 04:50 AM
