"abripl" wrote in message
oups.com... I'll give them an 8.5 on the bull**** scale... Thank you for your technical help. I assume you have tried them yourself and are giving an objective observation. Try them? You've got to be kidding. To quote the web pages: "However, when sudden braking or slowing occurs, the fluids continue to spin for several revolutions until they slow down to the wheel speed. Therefore, the fluid moving at high speed and weighing nearly 28 ounces per wheel whip around the ring at ten to fifteen revolutions per second. This weight, when pulled by gravity over the top of the wheel, "falls" over the front side of the wheel where the force is created which "pulls" the wheel down onto the pavement-JUST WHEN YOU NEED IT TO-on sudden braking over hard bumps or across sheets of water to create a road-hugging controlability and anti-sway, anti-drift and anti-trailer hop and bounce effect" RiiiiIIIiiight. Or, from the other web page: "The Company claims the dissimilar metallic composition of the balancer, i.e. steel mounting plate and aluminum balancing ring, dissipates wheel/tire heating while in operation. This feature is called "ThermoFlow" by the Company. Basic rules of thermal physics apply as different metals have different coefficients of contraction/expansion with convection heat transfer migrating to the metallic content with the highest coefficient of expansion/contraction, i.e. rapid transfer from the wheel/hub/tire assembly to the steel mounting plate to the aluminum tube." You don't have to pay for bull**** to smell bull****. 8.5 - you can't get a 10.0 without invoking space aliens AND anti-gravity. -- Geoff the sea hawk at wow way d0t com remove spaces and make the obvious substitutions to reply by mail Spell checking is left as an excercise for the reader. |
I think the down force is the result of gyroscopic precession which is 90 °
for the applied force. Balance rings are not new. Mark Landrol sells one for RVs with wooden prop that many are happy about. "Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote in message ... "abripl" wrote in message oups.com... I'll give them an 8.5 on the bull**** scale... Thank you for your technical help. I assume you have tried them yourself and are giving an objective observation. Try them? You've got to be kidding. To quote the web pages: "However, when sudden braking or slowing occurs, the fluids continue to spin for several revolutions until they slow down to the wheel speed. Therefore, the fluid moving at high speed and weighing nearly 28 ounces per wheel whip around the ring at ten to fifteen revolutions per second. This weight, when pulled by gravity over the top of the wheel, "falls" over the front side of the wheel where the force is created which "pulls" the wheel down onto the pavement-JUST WHEN YOU NEED IT TO-on sudden braking over hard bumps or across sheets of water to create a road-hugging controlability and anti-sway, anti-drift and anti-trailer hop and bounce effect" RiiiiIIIiiight. Or, from the other web page: "The Company claims the dissimilar metallic composition of the balancer, i.e. steel mounting plate and aluminum balancing ring, dissipates wheel/tire heating while in operation. This feature is called "ThermoFlow" by the Company. Basic rules of thermal physics apply as different metals have different coefficients of contraction/expansion with convection heat transfer migrating to the metallic content with the highest coefficient of expansion/contraction, i.e. rapid transfer from the wheel/hub/tire assembly to the steel mounting plate to the aluminum tube." You don't have to pay for bull**** to smell bull****. 8.5 - you can't get a 10.0 without invoking space aliens AND anti-gravity. -- Geoff the sea hawk at wow way d0t com remove spaces and make the obvious substitutions to reply by mail Spell checking is left as an excercise for the reader. |
I've wondered about these. By both brands, there is a mass of weights and
fluids that counteract the shake of imbalance. I never made it past Phy101 but how I see the problem is that a heavy spot of imbalance provokes a rotating object to a larger orbit. The instance of a car tire bouncing I have witnessed myself, but the low side was always constrained by the pavement. So, what causes the correction mass to seek the lighter low side? And what happens under the influence of an engines torsion vibration? The quick back & forth of the crank's twist, the wind and unwinding, Is the mass be heavy enough to lag behind the twist of how many.... 8 or 12 twists per revolution?? My guess about the rings on Rv's with the wooden props is its simply a matter having enough mass on the crank to absorb the torsion of the engine. Somethig heavy enough to steady down the running of the engine...Somewhat similar to running a chevy small block minus a flywheel, on the shop floor!. And a big question of all... why don't we commonly see more of these mechanisms on vehicles? Kent Felkins Tulsa "Cy Galley" wrote in message news:7Jjxf.698432$_o.515003@attbi_s71... I think the down force is the result of gyroscopic precession which is 90 ° for the applied force. Balance rings are not new. Mark Landrol sells one for RVs with wooden prop that many are happy about. "Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote in message ... "abripl" wrote in message oups.com... I'll give them an 8.5 on the bull**** scale... Thank you for your technical help. I assume you have tried them yourself and are giving an objective observation. Try them? You've got to be kidding. To quote the web pages: "However, when sudden braking or slowing occurs, the fluids continue to spin for several revolutions until they slow down to the wheel speed. Therefore, the fluid moving at high speed and weighing nearly 28 ounces per wheel whip around the ring at ten to fifteen revolutions per second. This weight, when pulled by gravity over the top of the wheel, "falls" over the front side of the wheel where the force is created which "pulls" the wheel down onto the pavement-JUST WHEN YOU NEED IT TO-on sudden braking over hard bumps or across sheets of water to create a road-hugging controlability and anti-sway, anti-drift and anti-trailer hop and bounce effect" RiiiiIIIiiight. Or, from the other web page: "The Company claims the dissimilar metallic composition of the balancer, i.e. steel mounting plate and aluminum balancing ring, dissipates wheel/tire heating while in operation. This feature is called "ThermoFlow" by the Company. Basic rules of thermal physics apply as different metals have different coefficients of contraction/expansion with convection heat transfer migrating to the metallic content with the highest coefficient of expansion/contraction, i.e. rapid transfer from the wheel/hub/tire assembly to the steel mounting plate to the aluminum tube." You don't have to pay for bull**** to smell bull****. 8.5 - you can't get a 10.0 without invoking space aliens AND anti-gravity. -- Geoff the sea hawk at wow way d0t com remove spaces and make the obvious substitutions to reply by mail Spell checking is left as an excercise for the reader. |
Fly,
There are more than just those two companies making them - like www.taabs-int.com, www.imiproducts.com and some reference to http://www.tirelife.com/ An article that discusses that is at http://www.landlinemag.com/Archives/...tires_life.htm There are several independent reviews of the devices and all indicate they work. There is an interesting demo machine that Centramatic.com distributies to ilustrate the balancing effect on a demo wheel. A demo video is available at http://www.centramatic.com/Demo/video2.mpg As far as I see it does not violate conservation of angular momentum. A free body in space will always be in angular balance about its CM whereas that is not the same case for rigid bodies rotating about a fixed axis - maybe that is the key: there extra bodies free to move. As to why they are not used more... probably the extra cost is prohibitive, to say an automobile where a $20 tire balance will do. But for big trucks it can pay off. I am not promoting the devices, but just have an open mind. Its so easy to put down others and not be creative oneself. |
RiiiiIIIiiight.
You don't have to pay for bull**** to smell bull****. 8.5 - you can't get a 10.0 without invoking space aliens AND anti-gravity. I just love all your scientific savy. |
Real Time to build an RV10 | [email protected] | Home Built | 13 | October 31st 05 02:20 AM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Prop balancing and assorted observations - long | Dave Hyde | Home Built | 10 | June 27th 04 01:08 AM |
IVO props... comments.. | Dave S | Home Built | 16 | December 6th 03 11:43 PM |
