#51
![]() "Newps" wrote From 800 feet??? I thought you were talking close to the ground. When I had my 182 I needed 450 feet to return to the runway I took off from, landing opposite direction. From 800 feet I will make a pattern of it and land the same way I took off. That sounds suspect as an over generalization, to me. A 152 will take a lot more time to descend that same altidude, vs a 182, or a sr-22, right? That of course is a relative term but from 800 feet you will have over a minute before you hit the ground. Two minutes with a 152, then? The time to get your head wrapped around the situation would seem, to me, to be an important factor. It should be enough for both cases, but how much lower is still enough, for the 152 brain in a sr-22? -- Jim in NC |
#52
![]() "Montblack" wrote I thought a Cirrus demo pilot died in a Cirrus a year or two ago. Not the test pilot in '99, but a factory designated demo safety pilot rep - whatever they're called. Wasn't that a gross mechanical failure, or something like that, or am I thinking of something else, "again." Damn, I hate CRS! -- Jim in NC |
#53
![]() Morgans wrote: "Newps" wrote The airplane will pitch to its trimmed speed. Always. How can it not? But how quickly will it do so? Will some designs do so, more rapidly than others? Not arguing, just asking. The only experience I have is with the 182 I had and my current Bonanza. Both will stay at whatever speed it is trimmed for, no hunting around. I would imagine the 172 is the same and I know the Debonair is the same because, well, it's the same plane. |
#54
![]() Morgans wrote: "Newps" wrote From 800 feet??? I thought you were talking close to the ground. When I had my 182 I needed 450 feet to return to the runway I took off from, landing opposite direction. From 800 feet I will make a pattern of it and land the same way I took off. That sounds suspect as an over generalization, to me. A 152 will take a lot more time to descend that same altidude, vs a 182, or a sr-22, right? I have never flown a 152 so I don't know exactly how it flies. However it is a strutted Cessna so I would fly it the same as the 182. The poster stated that they were turning downwind at 800 feet. Worst case there being no wind I would continue on downwind until one of two things happens. I get to 300 AGL or I get to the approach end of the runway. Never go past the approach end of the runway before turning base. Once turning base it is a constant bank turn at 80 mph IAS. Roll out over the runway and land. I do this nearly every time at my home airport because I use the small runway and there is rarely traffic. Half flaps at midfield when the runway is made and full flaps on base. That of course is a relative term but from 800 feet you will have over a minute before you hit the ground. Two minutes with a 152, then? I don't know, what is the fpm descent that you would get in a 152? In the 182 it was about 500-600 at 80 mph. |
#55
I thought we are talking abour SR20. I flew a lot of 182RG...but it is not a SR20. You are right on 182 but the one crashed is not your 182. From many test report, SR20 is even worse than SR22 on the aloaf. Our CSI (Cirrus Standardized Instructor) experienced several wing drop events during stall practices in a Cirrus during past few years. This plane is not as stable as your 182 at very low speed. Like many other posts, we have to respect each type and model that has their own charecterestic and envolope. Yeh, 182 and many other planes including gliders can adjust its own pitch to adapt power change...quickly and in almost all kind of pitch and power combinations. But it may not be the case for some other airplanes (in certain pitch and power combination). One example I can make is that a short-wing aerobatic aircraft such as Sukhoi 26 in a high-pitch low-speed climb out and then pull the power off, what will happend? Yeh the nose will drop dramatically, but will it remain stable without any control input? will it remaining its climb out speed when it start to dive? (again, no control input is allowed in your case). I don't think so. |
#56
So, if you don't lower the nose immediately the plane will
*automatically* stall and spin? I doubt it, No, of course not. But you beter do somthing to keep the plane in its design envolope. SR20 is not as stable as SR22 as many people reported. |
#57
it's generally unfamiliarity with the plane aggravated by
low-time/inexperienced pilots that's been the root of most of these accidents. With such little drag the plane shoud glide quite well although at a higher speed than other GA singles. Yeh, like there is the other guy keep preaching his 182 experience for a Cirrus. Some reports says a pilot get his master training completely in a Cirrus will have lower risk than a pilot move up to a Cirrus. I truely believe that. |
#58
![]() "cpu" wrote in message oups.com... I had my 182 I needed 450 feet to I thought we are talking abour SR20. I flew a lot of 182RG...but it is not a SR20. You are right on 182 but the one crashed is not your 182. From many test report, SR20 is even worse than SR22 on the aloaf. Our CSI (Cirrus Standardized Instructor) experienced several wing drop events during stall practices in a Cirrus during past few years. This plane is not as stable as your 182 at very low speed. Like many other posts, we have to respect each type and model that has their own charecterestic and envolope. Yeh, 182 and many other planes including gliders can adjust its own pitch to adapt power change...quickly and in almost all kind of pitch and power combinations. But it may not be the case for some other airplanes (in certain pitch and power combination). One example I can make is that a short-wing aerobatic aircraft such as Sukhoi 26 in a high-pitch low-speed climb out and then pull the power off, what will happend? Yeh the nose will drop dramatically, but will it remain stable without any control input? will it remaining its climb out speed when it start to dive? (again, no control input is allowed in your case). I don't think so. Assuming you have the S-26 trimmed for a given speed when the power is pulled at some point it will stabilize at the speed it was trimed for. There is one exception to this rule. The ground must not get in the way first. Should that happen all aircraft have an auto-trim function. |
#59
pulled at some point it will stabilize at the .... Well, your comment is correct only when the diving S-26 stability is in the envelope. If its current stability is out of the envelope, it may never reach its former trimed speed (or stable state). If you've readed the basic air dynamic in the ATP or commercial exam materials, you know there are 2 basic stabilities of an aircraft...dynamic and static stability. These 2 factors (and others) determine the performance envelope of an aircraft. If the air dynamic is that simple, all my friends in JPL and Boeing will be out of jobs by now. Why the most popular aircraft such as 182 (epscially most high-wings) will fall to its trim speed when power is lost because its stability envelope is large. So when power factor changed, in most of cases, its static stability will let the aircraft fall back into its balance state. Not all the aircrafts like this, you can proove it by common sense. (think about other types and models, jets, B2 bumber...etc.) |
#60
![]() More information: Peter Lopez was kind enough to send me this link: http://www.avpress.com/n/12/0112_s6.hts#thetop#thetop Shortly before the accident, the pilot radioed the tower requesting permission to simulate an emergency situation in which the engine stops shortly after takeoff and the pilot must make an emergency landing. In this simulation, the pilot cuts back on the engine power, similar to a driver taking his foot of the gas pedal, but the engine does not stop completely, Jones said. The aircraft made a low approach to the airport but did not touch down on the runway, then proceeded with the simulation, Jones said. The first attempt was apparently successful, and the pilot requested permission for a second attempt. It was in making the second attempt that the accident occurred, he said. The airplane crashed about two miles from the airfield, at 40th Street West and Avenue F. |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
Cirrus SR20 Fatal Crash in SC | Richard Kaplan | Piloting | 24 | April 22nd 04 10:47 AM |
