Say Altitude.
Old April 5th 04, 04:42 PM
OK... even still, though, the GPS isn't too accurate, and is based on absolute
altitude, not barometric altitude (mentioned previously). Also, the temperature
affects the altimeter... how high AGL were you? I read an interesting article (avweb,
I think) regarding temperature correction and obstacle clearance. When the altimeter
reading is down low and temps are cold, the higher you go the more error the altimeter
tells you. So, if the altimeter setting is down in the valley at 1000' MSL, but
you're shooting the approach with MEA at 10K', there can be issues with terrain
avoidance. Supposedly Canadian and AK folks get more indoctrination to this than
those in the lower '48.
-Cory
Hankal wrote:
:You didn't specify if your GPS was connected to the altitude encoder or not.
:If it's an IFR GPS, it'll be connected to the encoder, which only outputs the
:altitude
: My GPS is not connected.
: Under most conditions it agrees with my
: altimeter.
: It was just strange that the GPS and ATC
: did not not reflect the same as my altimeter.
: Hank
* The prime directive of Linux: *
* - learn what you don't know, *
* - teach what you do. *
* (Just my 20 USm$) *
Report Leaving Assigned Altitude? John Clonts Instrument Flight Rules 81 March 20th 04 02:34 PM
GPS Altitude with WAAS Phil Verghese Instrument Flight Rules 42 October 5th 03 12:39 AM
Change in TAS with constant Power and increasing altitude. Big John Home Built 6 July 13th 03 03:29 PM
High Altitude operations (Turbo charge???) Andre Home Built 68 July 11th 03 11:59 PM
