Thanks for the PIREP Allen!! I'll give this a whirl and see how it
behaves. Just more proof of how valuable these NG's are. Thanks again!! Jon Kraus '79 Mooney 201 4443H @ TYQ A Lieberman wrote: On Mon, 16 Jan 2006 08:08:53 -0800, Greg Siemon wrote: Are you instrument rated? . Are you tired of paying for instrument procedures you don't use? . Would you like to develop your own custom library of procedures? . Would you like to update your library automatically and unattended? . Would you like hands free Duat access for weather and filing flight plans? . Also Pocket PC support and laptop/tablet sync? . Would you like METAR/TAF weather by pointing with your mouse? . And an EFB? If you answered Yes then go to: http://cmensys.com From a users point of view (PIREP) on the above program.... I have been using this program for about a month. I have no relationship to the programmer *smile*, just a very satisfied user. Below are some rambling thoughts from my experiences with the program (in no particular order). The above only touches the surface of what the program can do. Once you get past the learning curve, which took me about an hour or so (FAQ and directions on the homepage are outstanding), you can do the following: File VFR and IFR flight plans. For me, I found it way "too easy" and ended up checking with FSS to see if indeed they got it. For those that were prior to web based interaction with DUATS, the program does allow interactive terminal access rather then the automated way should you choose this method. A lot of flexibility built in... Create a "trip tick" (like AAA) which is called trip pack in the program. This extracts all approach procedures for all aiports in your flight path (restricted to the corridor width you determine). Makes IFR much easier in planning for alternates, since this trip pack pulls all airports ONLY within your path. Also, organizes the charts you need in the order of your flight, which would make it much easier to find the "nrst" airport procedures rather then thumbing through NACO charts that I used in the past (which in my case may be in an entire different book for my long XC's). Once you get used to the "drag and drop" feature of the program, creating trip packs are a snap. Because you are downloading procedures over the internet, high bandwidth access would be recommended. Reduces weight in your plane. While the printing can be extensive (stock up on your printer cartridges and paper), it sure beats carrying NACO charts for states you will not be entering especially if you are only doing an in-state cross country. I have reduced a flight bag down to a notebook containing only the approach charts and XC enroute maps I need. At a glance on the map, shows the METAR weather (not radar), which for me gives a great overview of the weather within the very same program that I can get my charts. TAFs are displayed when you put your mouse over the airport. Program has been significantly upgraded since I began using it and programmer has been extremely responsive to my questions when I have contacted him. The program is designed for IFR pilots, though VFR pilots may get some use out of the weather feature since it shows only the text weather underneath your flight path. It leaves nothing to the imagination. AOPA flight planner shows the radar echoes, but no text. Can't run Golden Eagle flight planner to comment on my low end computer. The maps do not (at this time anyway) show airspace (B, C and D), but for IFR flights, airspace is transparent anyway. Maps do not show victor routes. The program DOES NOT require a lot of computer horsepower. It runs perfectly fine on my 500 mhz pentium 768K memory machine. Runs much more efficiently then Golden Eagle flight planner, and some what more efficiently then AOPA Real Time Flight planner. Can't give a PIREP on the EFB portion, since I don't have a tablet PC. Allen |
Instrument Checkride passed (Long) | Paul Folbrecht | Instrument Flight Rules | 10 | February 11th 05 02:41 AM |
Instrument Rating Checkride PASSED (Very Long) | Alan Pendley | Instrument Flight Rules | 24 | December 16th 04 02:16 PM |
Logging approaches | Ron Garrison | Instrument Flight Rules | 109 | March 2nd 04 05:54 PM |
PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 12:14 PM |
Enlisted pilots | John Randolph | Naval Aviation | 41 | July 21st 03 02:11 PM |
