I think it has to do with how fast the prop can 'push' air versus how fast
the plane is moving through the air. Imagine you are in a small boat with an outboard motor. The motor is moving the boat at 15 mph. You decide you want to go faster so you pull out an oar. You can only move the oar at a speed of 15 mph so the net force you are applying to the water is zero. If you were going slower, you could apply force to the water, thus making the boat inch ahead a little faster. wrote in message ... I'm not an engineer, nor do I play one on TV. I do find it interesting that the speed or velocity of the aircraft is a factor in figuring thrust in both the propeller and the jet propulsion formulas. Perhaps someone else can explain in it terms that you and I can understand. TC |
Why does a prop ice up so apparently readily? | Brian Whatcott | Piloting | 2 | November 9th 05 12:02 AM |
Why does a prop ice up so apparently readily? | Brian Whatcott | Instrument Flight Rules | 2 | November 9th 05 12:02 AM |
Why does a prop ice up so apparently readily? | The Visitor | General Aviation | 0 | November 8th 05 08:53 PM |
Why does a prop ice up so apparently readily? | Mike Rapoport | Instrument Flight Rules | 2 | November 8th 05 02:52 PM |
Sensenich Wood Prop Question | [email protected] | Owning | 3 | April 4th 05 02:32 PM |
