On Wed, 18 Jan 2006 13:40:21 -0600, Mitty wrote:
In pushrod motors the rocker arm noses running against the valve stems are splash oiled. Also the timing chain(s), the distributor drive gear, ... Pretty much it is only the bearings that are pressure oiled. i.e., mains, rods, cam(s). The engines pushrod engines I've assembled had hollow pushrods and fed pressurized oil to the rocker arms. The rocker arms were hollow and injected oil onto the valve stem to assist in cooling. Yes, the top of the valve stem did not have any direct injection so it did require splash oil for it's lubrication. That's where roller rockers help. Guess I hadn't thought that much about it for a long while. I stopped working as an auto mechanic a long time ago. Corky Scott |
![]() How, in a horizontally opposed engine with an external oil sump (like on the C85 or 0200 or lots of others) do the crankshaft lobes "splash" oil anywhere meaningful? The cam has to be lubed by some other mechanism. -----Original Message----- From: ] Posted At: Wednesday, January 18, 2006 3:05 PM Posted To: rec.aviation.ifr Conversation: Nasa Icing courses Subject: Engine Making Metal (Was: Nasa Icing courses) On Wed, 18 Jan 2006 13:40:21 -0600, Mitty wrote: In pushrod motors the rocker arm noses running against the valve stems are splash oiled. Also the timing chain(s), the distributor drive gear, ... Pretty much it is only the bearings that are pressure oiled. i.e., mains, rods, cam(s). The engines pushrod engines I've assembled had hollow pushrods and fed pressurized oil to the rocker arms. The rocker arms were hollow and injected oil onto the valve stem to assist in cooling. Yes, the top of the valve stem did not have any direct injection so it did require splash oil for it's lubrication. That's where roller rockers help. Guess I hadn't thought that much about it for a long while. I stopped working as an auto mechanic a long time ago. Corky Scott |
Jim Carter wrote:
How, in a horizontally opposed engine with an external oil sump (like on the C85 or 0200 or lots of others) do the crankshaft lobes "splash" oil anywhere meaningful? Disclaimer: I have no specific knowledge of the engine models mentioned. The oil that's pushed under pressure through the crankshaft rod and main bearings has to go somewhere. I picture it as a sort of whirling fog of oil droplets inside the crankcase. Specifically, *don't* picture the various crankshaft protrusions actually contacting the surface of a pool of oil, that's not what happens. The cam has to be lubed by some other mechanism. The cam bearings have their own oil passages and are lubricated under pressure from the oil pump. The cam lobes have no such lubrication. |
Nasa Icing courses | Jim Burns | Piloting | 96 | February 1st 06 04:16 AM |
Nasa Icing courses | Jim Burns | Owning | 108 | February 1st 06 04:16 AM |
ASRS/ASAP reporting systems - how confidential? | Tim Epstein | Piloting | 7 | August 4th 05 05:20 PM |
NASA Icing Course | [email protected] | Piloting | 3 | December 28th 04 05:18 PM |
FAA letter on flight into known icing | C J Campbell | Instrument Flight Rules | 78 | December 22nd 03 07:44 PM |
