Nasa Icing courses
Old January 18th 06, 09:05 PM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
Default Engine Making Metal (Was: Nasa Icing courses)
On Wed, 18 Jan 2006 13:40:21 -0600, Mitty wrote:
In pushrod motors the rocker arm noses running
against the valve stems are splash oiled. Also the timing chain(s), the
distributor drive gear, ... Pretty much it is only the bearings that are
pressure oiled. i.e., mains, rods, cam(s).
The engines pushrod engines I've assembled had hollow pushrods and fed
pressurized oil to the rocker arms. The rocker arms were hollow and
injected oil onto the valve stem to assist in cooling. Yes, the top
of the valve stem did not have any direct injection so it did require
splash oil for it's lubrication. That's where roller rockers help.
Guess I hadn't thought that much about it for a long while. I stopped
working as an auto mechanic a long time ago.
Corky Scott
Old January 19th 06, 02:07 PM posted to rec.aviation.ifr
Default Nasa Icing courses
Jim Carter wrote:
How, in a horizontally opposed engine with an external oil sump (like on
the C85 or 0200 or lots of others) do the crankshaft lobes "splash" oil
anywhere meaningful?
Disclaimer: I have no specific knowledge of the engine models mentioned.
The oil that's pushed under pressure through the crankshaft rod and main
bearings has to go somewhere. I picture it as a sort of whirling fog of oil
droplets inside the crankcase.
Specifically, *don't* picture the various crankshaft protrusions actually
contacting the surface of a pool of oil, that's not what happens.
The cam has to be lubed by some other mechanism.
The cam bearings have their own oil passages and are lubricated under pressure
from the oil pump. The cam lobes have no such lubrication.
Nasa Icing courses Jim Burns Piloting 96 February 1st 06 04:16 AM
Nasa Icing courses Jim Burns Owning 108 February 1st 06 04:16 AM
ASRS/ASAP reporting systems - how confidential? Tim Epstein Piloting 7 August 4th 05 05:20 PM
NASA Icing Course [email protected] Piloting 3 December 28th 04 05:18 PM
FAA letter on flight into known icing C J Campbell Instrument Flight Rules 78 December 22nd 03 07:44 PM
