I just remembered a local chromed C-85 engine that would "sag" on
takeoff after an overhaul. It was supposedly traced to inadequate ring gap. I find it hard to believe in your case though after your amount of time since OH. You might check the carb floatbowl fuel level with the clear flex standpipe connected into the carb drain port method. I'm otherwise outta ideas..... |
Replacing fuel cut-off valve with non-a/c part??? | Michael Horowitz | Owning | 46 | January 15th 05 10:20 PM |
Lycoming 0-360 factory overhaul core charges - Does Air Powertell the truth ? | Mike Spera | Owning | 6 | December 13th 04 01:13 AM |
Harley engine special | Brett | Home Built | 106 | May 28th 04 03:10 AM |
Q: Disecting a cut-off valve? | Michael Horowitz | Home Built | 0 | March 6th 04 01:47 PM |
Lycoming Sued | jls | Home Built | 0 | February 13th 04 02:01 PM |
