Master Buss Bar?
Old January 19th 06, 08:33 PM posted to rec.aviation.homebuilt
Default Master Buss Bar?
"RST Engineering" wrote in message
Conductivity for a hunk of metal 62 mils thick by quarter inch wide by a
foot long where you measure resistance in the micro-ohms means absolutely
nothing -- copper, brass, or aluminum. On the other hand, corrosion means
a lot -- like steel hardware on aluminum, no matter how good the plating
on the steel.
All good points. So, what is it that you are trying to say , in regards to
which material should be used, and which to stay away from?
Jim in NC
Old January 19th 06, 08:41 PM posted to rec.aviation.homebuilt
I said that I much prefer what is called a barrier strip terminal block, and
whether you get it at The Shack, Mouser, Digikey, etc. is immaterial.
However, if you are going to roll your own, I prefer brass, as it corrodes a
lot less than either copper or aluminum.
"Morgans" wrote in message
means a lot -- like steel hardware on aluminum, no matter how good the
plating on the steel.
to which material should be used, and which to stay away from?
Jim in NC
Old January 19th 06, 09:51 PM posted to rec.aviation.homebuilt
and whether you get it at The Shack, Mouser, Digikey, etc. is immaterial.
a lot less than either copper or aluminum.
I take, then, the terminal block (if it is what I am thinking of) will
require individual wires with terminals crimped onto them, to make the
connection with the individual breakers, or fuses?
Jim in NC
Old January 19th 06, 08:43 PM posted to rec.aviation.homebuilt
a foot long where you measure resistance in the micro-ohms means
absolutely nothing -- copper, brass, or aluminum. On the other hand,
corrosion means a lot -- like steel hardware on aluminum, no matter
how good the plating on the steel.
I took what he was saying to be that the difference in conductivity
between the materials mentioned for the size piece in question isn't a
factor worth worrying about. Compatibility with the connectors is much
more important as any galvanic corrosion between the connector and the
buss bar will cause substantially more resistance than will the
difference in buss bar material.
So pick the buss bar material which is most compatible with your
connector material.
Matt
Source for PA28-180 split master switch Mike Noel Owning 3 October 5th 05 02:29 AM
Master Jet Base MICHAEL OLEARY Naval Aviation 24 April 22nd 05 07:00 AM
Premade master and circuit breaker panel Corky Scott Home Built 6 March 19th 04 02:18 PM
ANG Woman Wing Commander Doesn't See Herself as Pioneer, By Master Sgt. Bob Haskell Otis Willie Military Aviation 0 March 18th 04 08:40 PM
Need G-103 Acro Master Cylinder Ray Lovinggood Soaring 5 September 30th 03 03:39 AM
