Why do jets leave a white trail behind them.
Old January 19th 06, 10:16 PM posted to rec.aviation.piloting
Default Why do jets leave a white trail behind them.
"Morgans" wrote in message
"AliR" wrote in message
Oh it's called Contrails, I didn't know that. I found lot's of info on
it
on the web. Thanks.
Which is short for "condensation trails."
The water produced from burning lots of gallons of Jet A fuel, producing
water, in vapor form, (lots of it) then exhausting it into very cold air
(20, 30, 40 degrees F, below zero) causes nearly all of that moisture
condense into visible water vapor, pretty quickly.
If you notice, sometimes, you see a space behind the jet where there is no
visible vapor, then it finally cools enough to become visible.
This same thing even happens behind piston engines. They are still
burning fuel, producing water, and having it cool greatly. It is most
often seen behind the high level, heavy bombers of WWII.
I remember the Jimmy Stewart flick, where he was called back into service
after WWII, in the Strategic Air Command. I think that was the name of
the movie, also. Anyway, if you don't get anything else out of the movie,
the flying scenes are "to die for." There are many minutes of seeing the
B-36's flying at very high altitude, with the contrails appearing a few
hundred yards behind the planes.
Kinda neat.
Of course, these planes had jet engines, and gasoline engines, and a lot
of them. Aluminum airplanes, and iron men! Make a point of seeing that
movie. It is worth it.
Extra points, for trivia. What kind/s of fuel did the B-36 carry?
Jim in NC
Since it had "six turnin' and four burnin'" did it have to carry AvGas and
JP?
It also carried a nuclear reactor aloft at one point:
http://www.cowtown.net/proweb/nb36h_jde.htm
Jay B
Old January 19th 06, 10:53 PM posted to rec.aviation.piloting
Purple 115/145 avgas, burns just fine in the jet and was
required by the big P&W radials.
"Jay Beckman" wrote in message
news:EcUzf.9831$jR.3049@fed1read01...
lot's of info on
| it
| on the web. Thanks.
fuel, producing
into very cold air
that moisture
where there is no
visible.
They are still
greatly. It is most
back into service
was the name of
out of the movie,
appearing a few
| Kinda neat.
engines, and a lot
B-36 carry?
| Jim in NC
carry AvGas and
| JP?
| Jay B
Old January 19th 06, 11:11 PM posted to rec.aviation.piloting
"Jim Macklin" wrote in message
news:LMUzf.66027$QW2.60514@dukeread08...
Yep. As I recall, the jet engines did also not run continuously, but were
turned off, after takeoff and climb. Correct?
Jim in NC
Old January 20th 06, 12:26 AM posted to rec.aviation.piloting
They cruised on just the piston engines and used all 10 for
take-off and attack runs, I think they did the climb using
just the pistons.
| "Jim Macklin" wrote
in message
| Jim in NC
Boeing Boondoggle Larry Dighera Military Aviation 77 September 15th 04 02:39 AM
Flying the Santa Fe Trail Story: long JJS Piloting 19 April 9th 04 02:02 AM
FS: 1986 "Fighting Jets" Hardcover Edition Book J.R. Sinclair Military Aviation 3 January 22nd 04 05:01 PM
FS: 1986 "Fighting Jets" Hardcover Edition Book J.R. Sinclair Military Aviation 0 December 2nd 03 05:10 AM
FS: 1986 "Fighting Jets" Hardcover Edition Book Jim Sinclair Aviation Marketplace 0 September 8th 03 07:43 AM
