![]() "David Rind" wrote in message ... If an approach has a hold in lieu of a PT, but the chart says "No PT", is the hold optional, or is it only available with ATC authorization the way a PT would be in this situation? ATC authorization is required. I was looking at the ILS 2 approach into EEN, and there is a segment at 4000' from an IAF at the GDM VOR marked No PT. The intercept altitude for the ILS is 2600', which is a fairly quick descent along the localizer (though certainly doable). Fairly quick descent? If your clearance is via GDM and you've been cleared for the approach, you can descend to 4000 once you reach GDM. If you reach 4000 by CAHOW, you'll find yourself about 240 feet BELOW the glideslope as you join the localizer. If you wanted to take a turn around the hold to descend, do you need ATC authorization the way you would for a PT? Yes. I can't tell from the wording in the AIM though perhaps I'm missing the place where it is spelled out. § 91.175 Takeoff and landing under IFR. (j) Limitation on procedure turns. In the case of a radar vector to a final approach course or fix, a timed approach from a holding fix, or an approach for which the procedure specifies "No PT," no pilot may make a procedure turn unless cleared to do so by ATC. |
nk.net If an approach has a hold in lieu of a PT, but the chart says "No PT", is the hold optional, or is it only available with ATC authorization the way a PT would be in this situation? ATC authorization is required. What are some of the factors in ATC's decision on this request? The only times I can think of that I'd request a hold would be to configure my cockpit (which would hopefully have been done prior to entering the approach segment) or to drop altitude if I'd been cleared inbound high for whatever reason. -- John T http://tknowlogy.com/TknoFlyer http://www.pocketgear.com/products_s...veloperid=4415 ____________________ |
![]() "John T" wrote in message ws.com... What are some of the factors in ATC's decision on this request? Other traffic. |
Steven P. McNicoll wrote:
§ 91.175 Takeoff and landing under IFR. (j) Limitation on procedure turns. In the case of a radar vector to a final approach course or fix, a timed approach from a holding fix, or an approach for which the procedure specifies "No PT," no pilot may make a procedure turn unless cleared to do so by ATC. Yes, of course. This is what says that you cannot do a PT in this situation without ATC authorization (as I pointed out I understood in my initial post). My question was whether a holding pattern in lieu of a PT fell under the same rule. What caused my question is that in the AIM (5-4-8, section b) the discussion splits limitations on PTs and on holds in lieu of PTs: 1. In the case of a radar initial approach to a final approach fix or position, or a timed approach from a holding fix, or where the procedure specifies NoPT, no pilot may make a procedure turn unless, when final approach clearance is received, the pilot so advises ATC and a clearance is received to execute a procedure turn. 3. When a holding pattern replaces a procedure turn, the holding pattern must be followed, except when RADAR VECTORING is provided or when NoPT is shown on the approach course. So that in section 1 above it says you may not do a PT if it says NoPT, while in section 3 it says you must do a hold in lieu of a PT unless it says NoPT. Under section 3 alone, it would seem possible that a hold in lieu of a PT is permitted but not required if it says NoPT. I write this just to explain why I was unsure. Everyone here seems to agree that just like a PT, a hold in lieu of a PT is not permitted if it says NoPT. -- David Rind |
Holds for currency requirements | Paul Tomblin | Instrument Flight Rules | 8 | March 12th 04 06:49 PM |
