Is there any good reason to use the Ford instead of the Buick V6?
There are a lot more Buick V6s out there. Also, there is a lot of support from the aftermarket, hot rod and racing business for the Buick engine and apparently none at all for the Ford V6. I don't have personal experience. However, my fellow chapter members have told me that the Ford V6 engine is considerably lighter as it comes in (or from) a car. That said, the aluminum heads and blocks alleged to be available should make a lighter and stronger engine. BTW, the name "Bow Tie Racing" was mentioned, but yielded no plausible result in my quick web search. The only word of caution to which I can personally attest (from my younger and crazier days) is to be *very* careful of racing and hot rodding parts designed to give you oversized ports and manifolds. As you increase the diameter of the passages, you also decrease the velocity of the gasses; which will result in a very "cammy" high speed engine with poor pulling power and a poor ability to turn a fixed pitch propeller. |
Book Review: Converting Auto Engines for Experimental Aircraft , Finch | Paul | Home Built | 0 | October 18th 04 10:14 PM |
P-3C Ditches with Four Engines Out, All Survive! | Scet | Military Aviation | 6 | September 27th 04 01:09 AM |
What if the germans... | Charles Gray | Military Aviation | 119 | January 26th 04 11:20 PM |
Corvair Engine Conversion Breakin Success | Dick | Home Built | 1 | January 11th 04 02:06 PM |
Corvair Conversion | Gig Giacona | Home Built | 17 | October 27th 03 09:43 PM |
