Lowrance GPS
Old January 21st 06, 05:31 PM posted to rec.aviation.piloting
Default Lowrance GPS
Dave wrote:
Yes..all good points...
But certianly a flub on their part, and the 11 ft of cable is not
necessarily convenient.
While not ideal, Garmin's solution is certainly more convenient than a
comparable WxWorx + PDA or TabletPC installation.
I suspect that the magnets in the XM receiver were not a mistake, but
rather an intentional design element that appeals to the automotive
market. Garmin was able to reduce production costs on the receiver by
manufacturing only one type of receiver.
Still, I would have preferred to see a magnetic base that screws on to
the receiver. Such a design element could be easily excluded from the
aviation kits, but included with the automotive kits. However, I just
don't see why the magnets should be of big practical impact for most
people.
and Lowrance does NOT have XM capability.
Yet,...... lately, the DO have a habit of delivering on what they say
they will...
I haven't seen any official comment from Lowrance on an XM-enabled
portable GPS unit.
Being "second" in introducing a new feature is not always a bad
thing..
No, but Garmin has done just about everything right with their
implementation. I hope that Lowrance does bring a unit to market at a
lower price, because I think that XM weather is fantastic, and a
capability that more pilots should employ.
Old January 22nd 06, 01:42 AM posted to rec.aviation.piloting
Comments interspersed below..
On Sat, 21 Jan 2006 12:31:08 -0500, Jonathan Goodish
Agreed... much better....
They were not, they just did not think very much about the aviation
market..
In fact, they did not think at all...
but rather an intentional design element that appeals to the automotive
market.
Correct
Ummm... a lot of customers would have appreciated it if they had
"saved" the cost of the magnets....
Agreed....
However, I just
people.
They are not, for MOST customers, but they are aparently an serious
issue with the pilot customers, and should be..
Simply put, it is in the instruction books on flying, boating,
navigation, the manuals for the compasses, (marine & aviation),
placards on instrument panels, even some sunglasses....DO NOT, EVER,
FOR ANY REASON , place ANY object near the magnetic compass, in case
it MIGHT affect it.
Regardless if you or others EVER use it, it is the LAST available
directional instrument available when everything else goes tango
uniform.
I use mine constantly, to set the DG, and to cross check all
directional equipment...
Then, all of a sudden, we have an experienced aviation manufacturer
BUILD magnets in a device to be placed on the cowl of an aircraft !!
Then when CUSTOMERS complain, with VERY valid reasons to do so,
Garmin says, in effect, leave them in, or void your warranty.... (!)
If Lowrance or any other manufacturer "has to catch up" well, they
have a great opportunity..
The (alleged) leader just stumbled.... big time...
And instead if saying , "oops, sorry, lets fix this now" , they say,
tough, thats the way it is, don't void your warranty.....
Not the best marketing/service strategy in a tight , well connected
market - hmmmm?
.........word travels fast.... (and has)
Dave
they will...
portable GPS unit.
thing..
Old January 22nd 06, 03:12 AM posted to rec.aviation.piloting
it MIGHT affect it.
None of my books make such a statement. I suspect that the deviation
cards in the aircraft most of us fly are not very accurate, unless you
have a compass swing done periodically. There are lots of things that
surround the magnetic compass that could affect it. A portable XM
receiver that can be easily removed if the compass is your last hope of
survival doesn't rate very highly on my list of concerns.
JKG
Old January 22nd 06, 03:35 AM posted to rec.aviation.piloting
The one in my Maule was way off. The card provided by the factory said it was 5
degrees off all the cardinal headings. With the engine and avionics on, I saw
from 5 to over 15 degrees off those headings using a Army nav compass.
George Patterson
Coffee is only a way of stealing time that should by rights belong to
your slightly older self.
AirMap 1000 - 2000 , Great CS from Lowrance Dave Piloting 4 September 8th 05 02:10 AM
Smooth Lowrance Airmap 1000 updates Longworth Piloting 2 August 16th 05 01:52 AM
Problem with Lowrance Database Update? Stuart Grant Piloting 5 December 24th 04 03:16 AM
Portable GPS Sugggestion (Lowrance vs Garmin) Pudealee Piloting 0 September 6th 04 05:19 AM
GPSMAP 195/196 vs. Lowrance AIPMAP 1000 JJS Piloting 4 March 9th 04 08:14 PM
