![]() Ron Rosenfeld wrote: It has nothing to do with MSA. Basically, weather needs to be at least 1000/3, and the pilot needs to have the airport or an a/c to follow in sight. While the 1000/3 applies because you have to have VFR to get a visual the ceiling needs to be higher than that because there are no MVA's that are even as low as 1000 feet. So practically speaking the ceiling needs to be higher than the MVA for that area. |
![]() "Newps" wrote in message news ![]() While the 1000/3 applies because you have to have VFR to get a visual the ceiling needs to be higher than that because there are no MVA's that are even as low as 1000 feet. So practically speaking the ceiling needs to be higher than the MVA for that area. An aircraft can sight the field through a broken layer and be cleared for a visual approach. |
On Fri, 09 Apr 2004 19:49:41 GMT, Newps wrote:
While the 1000/3 applies because you have to have VFR to get a visual the ceiling needs to be higher than that because there are no MVA's that are even as low as 1000 feet. So practically speaking the ceiling needs to be higher than the MVA for that area. It only has to be reported as 1000/3 at the airport, not at your present position. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
![]() Ron Rosenfeld wrote: On Fri, 09 Apr 2004 19:49:41 GMT, Newps wrote: While the 1000/3 applies because you have to have VFR to get a visual the ceiling needs to be higher than that because there are no MVA's that are even as low as 1000 feet. So practically speaking the ceiling needs to be higher than the MVA for that area. It only has to be reported as 1000/3 at the airport, not at your present position. That's true but if the ceiling really is only 1000 you ain't gettin' in. |
![]() "Newps" wrote in message news:JfTdc.114206$JO3.80855@attbi_s04... That's true but if the ceiling really is only 1000 you ain't gettin' in. That's not necessarily true. A ceiling is the height above the surface of the lowest layer of clouds or obscuring phenomenon that is reported as broken, overcast, or obscuration. A broken layer covers 5/8 to 7/8 of the sky, aircraft can sight the field with a broken layer at 1000 feet and be cleared for a visual approach. |
On Sat, 10 Apr 2004 14:10:50 GMT, Newps wrote:
That's true but if the ceiling really is only 1000 you ain't gettin' in. If you restrict the "ceiling" to "overcast" conditions, I would agree. But that often is not the case. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
Report Leaving Assigned Altitude? | John Clonts | Instrument Flight Rules | 81 | March 20th 04 02:34 PM |
Night over water | Stuart King | Instrument Flight Rules | 43 | March 4th 04 01:13 AM |
Completing the Non-precision approach as a Visual Approach | John Clonts | Instrument Flight Rules | 45 | November 20th 03 05:20 AM |
Visual Appr. | Stuart King | Instrument Flight Rules | 15 | September 17th 03 08:36 PM |
