![]() "COLIN LAMB" wrote in message ink.net... In fact, you can often hang a auto lamp across the battery with a digital voltmeter and watch the voltage drop. The less drop, the better the battery. That is exactly how I have been doing it for years, and I have never found a need for anything more fancy. For small gel cells, (as are used in gliders) I use a digital voltmeter and a 50-watt sealed beam light. For larger batteries, I use a commercial load tester that you can buy at NAPA or any similar auto parts store for about $50.00 US. Vaughn |
Vaughn wrote:
"COLIN LAMB" wrote in message ink.net... In fact, you can often hang a auto lamp across the battery with a digital voltmeter and watch the voltage drop. The less drop, the better the battery. That is exactly how I have been doing it for years, and I have never found a need for anything more fancy. For small gel cells, (as are used in gliders) I use a digital voltmeter and a 50-watt sealed beam light. For larger batteries, I use a commercial load tester that you can buy at NAPA or any similar auto parts store for about $50.00 US. It sounds like you are effectively doing an internal resistance measurement. Do you have chart of volt drop, load, and good/ok/bad decision for various size batteries? I've not seen that sort of thing in battery data sheets, so I assume you have to develop the numbers empirically. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
![]() "Eric Greenwell" wrote in message ... It sounds like you are effectively doing an internal resistance measurement. Exactly. I find that internal resistance is a great measure of the health of a battery. Do you have chart of volt drop, load, and good/ok/bad decision for various size batteries? No, but I usually consider any drop over a volt or so to be suspect (assuming an appropriate load for the size of battery). In my work, I often have the advantage of having identical batteries to compare against each other. I've not seen that sort of thing in battery data sheets, so I assume you have to develop the numbers empirically. True, but for auto-sized batteries the tester I mention (a very common type) comes with markings that make a great starting point. Vaughn |
Battery Question | [email protected] | Soaring | 19 | September 15th 05 01:38 AM |
Batteries, charger for Yaesu handheld - NiCad or NiMH? | David Herman | Owning | 10 | November 7th 04 04:30 PM |
14 Volt Gel Cell? | Joe Allbritten | Soaring | 32 | May 11th 04 01:37 AM |
Icom A5 Battery Tester ?? | Harry Gordon | Piloting | 5 | January 10th 04 01:29 PM |
Becker AR 4201 or Microair 760 Transceiver | Steve B | Soaring | 23 | September 15th 03 06:32 PM |
