O-320 3.5 crank speed vibration
Old January 23rd 06, 07:38 PM posted to rec.aviation.homebuilt,rec.aviation.owning
Default O-320 3.5 crank speed vibration
Also - check the prop blade resonant frequency in the flapping mode
without the engine running, hitting it at a tip with the tip of your
index finger.
You might be able to hear it with your ear.
Old January 23rd 06, 08:08 PM posted to rec.aviation.homebuilt,rec.aviation.owning
("nrp" wrote)
without the engine running, hitting it at a tip with the tip of your index
finger.
Oh good. You formed my question for me.
I was wondering if there were any old tricks/shortcuts used back in WWI or
WWII? Or even in the old barnstorming days - out next to someones ...barn?
Not perfect fixes, but 'half-way to the wall' solutions.
Montblack
Old January 23rd 06, 08:48 PM posted to rec.aviation.homebuilt,rec.aviation.owning
Its kinda interesting to critically watch the rotational plane of a
brightly lit (daylight) propeller against a dark background, as someone
else varies the engine RPMs. I've seen the blade tips move like 1/2
inch out of plane at certain bad rpms.
Old January 23rd 06, 09:13 PM posted to rec.aviation.homebuilt,rec.aviation.owning
Or a variable speed party strobe...
Sheds an interesting light on things like that.
Richard
Old January 23rd 06, 09:14 PM posted to rec.aviation.homebuilt,rec.aviation.owning
Possible reasons for out of balance are
propeller static balance bad or
engine mounts bad.
Old January 23rd 06, 08:24 PM posted to rec.aviation.homebuilt,rec.aviation.owning
Bingo!
I have just determined that the strip of metal I used to mount the
sensor to the front of the engine has a resonant frequency (with the
sensor attached (of course)) around 95 HZ which is very close to the
frequency of the spike I was seeing.
I think that solves the mystery of the 3.5 crank vibration.
Many thanks to those who replied, I learnt something today!
Mark
Engine Balancing and Resonance Vibration Problem AllanFuller Owning 13 September 12th 05 12:51 AM
Landing and T/O distances (Was Cold War ALternate Basing) Guy Alcala Military Aviation 3 August 13th 04 12:18 PM
Va and turbulent air penetration speed. Doug Instrument Flight Rules 70 January 11th 04 08:35 PM
Speed Astir Guy Acheson Soaring 0 December 11th 03 02:24 AM
