O-320 3.5 crank speed vibration
Old January 23rd 06, 06:42 PM posted to rec.aviation.homebuilt,rec.aviation.owning
Default O-320 3.5 crank speed vibration
Stuart How many blades on the prop? Variable pitch? What
Stuart balancer are you using? Is it nose wheel or tail dragger?
It's a 2 blade metal prop (Sensenich) and I am using the spectrum mode
of a Smart Avionics PB-1 balancer to look at the vibration spectrum.
As I am actually the manufacturer of the PB-1, I believe it to be
trustworthy!
The spectrum display very clearly shows big peaks at 0.5 and 3.5 crank
speed and not much elsewhere.
A previous post suggested re-indexing the prop and that sounds like it's
worth trying.
What I really would like to find out is if there are any known engine
problems that can give rise to that particular vibration frequency.
Mark
Old January 23rd 06, 06:55 PM posted to rec.aviation.homebuilt,rec.aviation.owning
I am unaware of anything within a 4 cyl opposed engine that would
theoretically that would give anything at the 3.5 harmonic. I think
you might be looking at a non-linearity in the mount (is it a dynafocal
or a straight conical mouint?) or in the transducer(s) mounting.
I'd guess the 3.5 order output to be comparatively insignificant
compare to the 0.5 harmonic as far as human discomfort is concerned.
Do try the prop indexing thing. Let us know the results.
Good luck & THX
Old January 23rd 06, 07:11 PM posted to rec.aviation.homebuilt,rec.aviation.owning
Thanks for the reply,
Sorry, off the top of my head, I don't know what kind of engine mount
it is. I shall ask the aircraft's owner.
Checking the transducer mounting is a good idea even if it only
removes another unknown from the equation.
What I should have done at the time was vary the RPM more and see how
the 3.5 order vibration magnitude changed. That surely would have
indicated whether it was a resonance at a particular RPM.
What's nagging at me is the magnitude of the 3.5 order vibration. 0.5
IPS equates to quite a lot of acceleration at that frequency and
acceleration means force!
Mark
Old January 23rd 06, 07:34 PM posted to rec.aviation.homebuilt,rec.aviation.owning
removes another unknown from the equation -
Maybe your xdcr mount is resonant at the 3.5 harmonic? Change the RPM
& see what the measurments show.
Its still only 1/4 g approx. Not that much for a piece of cheap
machinery.......!
Old January 23rd 06, 07:38 PM posted to rec.aviation.homebuilt,rec.aviation.owning
Also - check the prop blade resonant frequency in the flapping mode
without the engine running, hitting it at a tip with the tip of your
index finger.
You might be able to hear it with your ear.
Old January 23rd 06, 08:08 PM posted to rec.aviation.homebuilt,rec.aviation.owning
("nrp" wrote)
without the engine running, hitting it at a tip with the tip of your index
finger.
Oh good. You formed my question for me.
I was wondering if there were any old tricks/shortcuts used back in WWI or
WWII? Or even in the old barnstorming days - out next to someones ...barn?
Not perfect fixes, but 'half-way to the wall' solutions.
Montblack
Old January 23rd 06, 08:48 PM posted to rec.aviation.homebuilt,rec.aviation.owning
Its kinda interesting to critically watch the rotational plane of a
brightly lit (daylight) propeller against a dark background, as someone
else varies the engine RPMs. I've seen the blade tips move like 1/2
inch out of plane at certain bad rpms.
Old January 23rd 06, 09:13 PM posted to rec.aviation.homebuilt,rec.aviation.owning
Or a variable speed party strobe...
Sheds an interesting light on things like that.
Richard
Old January 23rd 06, 09:14 PM posted to rec.aviation.homebuilt,rec.aviation.owning
Possible reasons for out of balance are
propeller static balance bad or
engine mounts bad.
Old January 23rd 06, 08:24 PM posted to rec.aviation.homebuilt,rec.aviation.owning
Bingo!
I have just determined that the strip of metal I used to mount the
sensor to the front of the engine has a resonant frequency (with the
sensor attached (of course)) around 95 HZ which is very close to the
frequency of the spike I was seeing.
I think that solves the mystery of the 3.5 crank vibration.
Many thanks to those who replied, I learnt something today!
Mark
O-320 3.5 crank speed vibration Mark Burton Owning 12 January 23rd 06 09:14 PM
Engine Balancing and Resonance Vibration Problem AllanFuller Owning 13 September 12th 05 12:51 AM
Landing and T/O distances (Was Cold War ALternate Basing) Guy Alcala Military Aviation 3 August 13th 04 12:18 PM
New Film: The Need For Speed - Going to war on drugs Phil Carpenter Military Aviation 0 July 23rd 03 07:43 AM
