New gun
Old January 24th 06, 03:37 PM posted to rec.aviation.piloting
Default New gun
"Morgans" wrote:
Some people confuse descent with acceleration. A mere constant-rate
descent (apprx. zero net force) does nothing to change the analysis.
You lack the ability to change real life application into a physics
problem.
I'm not sure you are in a position to criticize.
If you have your engines set to hold constant speed in level flight,
then push over into descent, what happens to your speed?
There is a brief acceleration until the airplane reaches its new trim
speed, then (roughly, omitting other factors such as greater thrust at
lower altitudes, ...) it will hold that new higher speed.
Case closed. Now you can use some of that acceleration into pushing
against the guns.
But that acceleration is brief! They won't fire the gun during a
pushover maneuver that is changing aircraft pitch (= aim point).
What I hope you mean that the accumulated extra speed (= momentum)
gives it a greater margin. Indeed, according to one source, the
maximum speed for the A10 is in the 400kt range. On the other hand,
pulling out of such a dive, after firing at the ground (and thus not
too high to start with), would be quite a feat. I'm sure one could
cook up some simple equations to wow oneself with the necessary G
load.
Everyone seems to forget that the guns on an A-10 are only used in 2
to 4 second bursts [...]
Only "seems".
- FChE
