Cost of State Registration?
Old January 24th 06, 09:09 PM posted to rec.aviation.piloting
Default Cost of State Registration?
"Jay Beckman" wrote in message
news:_8wBf.11272$jR.8415@fed1read01...
"Jim Macklin" wrote in message
news:jLvBf.69411$QW2.129@dukeread08...
How many miles of roads does your car use, compared to miles
of runway?
Well, that really wasn't my point...
I didn't put a lot of emphasis on it, but what I was getting at was the
cost to register versus the cost of the vehicle being registered.
But your "point" ignored the reality of the situation. At least in some
respects, supporting a motor vehicle costs more than supporting an
airplane. So why shouldn't the tax on a "per-value" basis be more?
Valid point.
I don't think it's legitimate to compare taxes between different kinds of
goods and expect them to come out the same on a "per-value" basis.
Otherwise, we could just have a single sales/use tax on everything, right?
Also true.
Does it seem odd to you that your home isn't taxed the same rate on a
"per-value" basis as your car? That would be just as valid a point as the
one you were making in your post.
Fair 'nuff.
Jay B
  #62
Old January 24th 06, 09:25 PM posted to rec.aviation.piloting
Governments only have a right to tax for services rendered
and only for services actually wanted by the public.
Passing a law to require that you use a "service" just so
you can tax is an abuse. Unfortunately, governments have
the power to tax for whatever they want, whenever they want.
As has been said, the power to tax is the power to destroy.
Most state aviation departments, if they even have one, do
little but duplicate Federal regulations, inspections and
controls. Small airports are owned by cities, counties and
private individuals [who are taxed very heavily] and few
states actually own any airports. Some states do provide
real services and the pilots and passengers in those states
get a benefit. But many states just tax because they can.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
| "Jim Macklin" wrote
in message
miles
| of runway?
getting at was the cost
registered.
| Aircraft cost more than cars but (it would seem) cost far
less to register
| on a "per thousand dollars of value" basis.
| I was mearly expressing a sense of suprise...I'm certainly
not advocating
| that pilots dig deeper than they already have to.
| And as I said, I'm not an owner so I'm only reacting to
the actual numbers
| being quoted without a complete understanding of additonal
taxes and fees
| that go with buying an owning.
| Jay B
  #63
Old January 25th 06, 03:06 AM posted to rec.aviation.piloting
Jay Beckman wrote:
I didn't put a lot of emphasis on it, but what I was getting at was the cost
But you still seem to have missed the point. The major point of license fees is
to pay the costs of infrastructure. There's a lot of that with cars, so the
registration cost is high. There's comparatively little of that for light
aircraft, so the registration fees are low. The fees have nothing to do with the
relative values of the aircraft and autos, and shouldn't have.
George Patterson
Coffee is only a way of stealing time that should by rights belong to
your slightly older self.
  #64
Old January 25th 06, 04:10 AM posted to rec.aviation.piloting
"George Patterson" wrote in message
news:6XBBf.7851$zh2.3507@trnddc01...
fees is to pay the costs of infrastructure. There's a lot of that with
cars, so the registration cost is high. There's comparatively little of
that for light aircraft, so the registration fees are low. The fees have
nothing to do with the relative values of the aircraft and autos, and
shouldn't have.
George Patterson
As it applies in your explaination, I'd have to agree.
Now, let me ask this (simply as a point of discussion):
Does our use of aviation's "infrastructure" really end when the wheels leave
the ground?
With the FAA crying poverty and the spectre of "Use Fees" looming over GA,
what happens when the argument becomes:
Pilots are using an "aviation infrastructure" anytime we're flying in the
National Airspace System."
- IFR flying?
- VFR pilots requesting flight following?
- Operations at Towered airports?
- Class B, C or D transitions?
- FSS?
- Flight Watch?
Are we ever truly free of, or without need of, the GA "infrastructure?"
Your thoughts?
Jay B
  #65
Old January 25th 06, 08:25 AM posted to rec.aviation.piloting
news:SSCBf.11315$jR.11298@fed1read01...
Depends on what services you actually use. But plenty of pilots use
practically no infrastructure except the pavement they operate from.
That said, I think it's a mistake to expect any of the fees to be rational.
Registration fees for cars are not exclusively used for roads and related
maintenance for example. The actual cost of registration varies from state
to state (just as it does for airplanes), as does the means of calculating
(fees, taxes, some combination).
The different in infrastructure expenses is just a single example of why the
fees can't really be compared directly. It's not an entire explanation, nor
should one expect the fees to be otherwise comparable if the infrastructure
costs did happen to be similar, or even the same.
The cost of registering an airplane, and of registering a car, is fairly
arbitrary. Fees are structured however each individual state chooses to
structure them, with the money going to wherever each individual state
choose to send them. Each state constitution may restrict those aspects,
but each state has its own constitution as well. Some states may appear to
make more sense than some others, but I don't think there's any reason for
any state to be expected to be entirely sensible. It's government, after
all.
Pete
  #66
Old January 25th 06, 09:00 AM posted to rec.aviation.piloting
Some states may appear to make more sense than some others, but I don't
think there's any reason for any state to be expected to be entirely
sensible. It's government, after all.
Pete
Pete,
Ain't that the truth..
Jay B
  #67
Old January 25th 06, 01:32 PM posted to rec.aviation.piloting
IIRC:
I hate to tell you this but most registration money goes into the states
General (ie, **** away on political favors) Fund (about 75% in AZ if my
B-I-L is correct).
Same thing with fuel taxes.
Infrastructure is often paid out of federal grant money and highway funds.
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 05:12 AM
