"Steven P. McNicoll" wrote in message link.net...
"Snowbird" wrote in message om... Had you reported a preceding aircraft in sight that had been cleared for a visual approach? Nope. No one else going in to that non-towered airport IFR. Typical exchange would go something like "XX Center, Grumman 123 requests slow descent into Podunk" "Grumman 123, descend and maintain three thousand." (3000 will lose radar coverage and radio contact will be iffy) (around 3500 ft) "Grumman 123, radar contact lost, you are cleared for the visual approach into Podunk, no observed traffic between you and the airport, change to advisory approved, report cancellation with Flight Service" FAA Order 7110.65P Air Traffic Control Chapter 7. Visual 2. The airport in sight at airports without a control tower. That looks pretty unambiguous. My guess is what I've run into is someone who knows if he waits to clear me until I report the airport in sight, the chances that he'll have lost both radar contact and comms with me are pretty high, and has decided to simplify his life. Cheers, Sydney b. Resolve potential conflicts with all other aircraft, advise an overtaking aircraft of the distance to the preceding aircraft and speed difference, and ensure that weather conditions at the airport are VFR or that the pilot has been informed that weather is not available for the destination airport. Upon pilot request, advise the pilot of the frequency to receive weather information where AWOS/ASOS is available. PHRASEOLOGY- (Ident) (instructions) CLEARED VISUAL APPROACH RUNWAY (number); or (ident) (instructions) CLEARED VISUAL APPROACH TO (airport name) (and if appropriate) WEATHER NOT AVAILABLE OR VERIFY THAT YOU HAVE THE (airport) WEATHER. REFERENCE- FAAO 7110.65, Visual Separation, Para 7-2-1. c. Clear an aircraft for a visual approach when: 1. The aircraft is number one in the approach sequence, or 2. The aircraft is to follow a preceding aircraft and the pilot reports the preceding aircraft in sight and is instructed to follow it, or NOTE- The pilot need not report the airport/runway in sight. 3. The pilot reports the airport or runway in sight but not the preceding aircraft. Radar separation must be maintained until visual separation is provided. d. All aircraft following a heavy jet/B757 must be informed of the airplane manufacturer and model. EXAMPLE- "Cessna Three Four Juliet, following a Boeing 757, 12 o'clock, six miles." e. Inform the tower of the aircraft's position prior to communications transfer at controlled airports. ARTS/STARS functions may be used provided a facility directive or LOA specifies control and communication transfer points. f. In addition to the requirements of para 7-4-2, Vectors for Visual Approach, and subparas a, b, c, d, and e, ensure that the location of the destination airport is provided when the pilot is asked to report the destination airport in sight. g. In those instances where airports are located in close proximity, also provide the location of the airport that may cause the confusion. EXAMPLE- "Cessna Five Six November, Cleveland Burke Lakefront Airport is at 12 o'clock, 5 miles. Cleveland Hopkins Airport is at 1 o'clock 12 miles. Report Cleveland Hopkins in sight." REFERENCE- FAAO 7110.65, Approaches to Multiple Runways, Para 7-4-4. |
(Michael) wrote:
That sounds realistic. On the other hand, the controller has an option that is just as simple and not contrary to regulation. The option is a cruise clearance. That allows you to shoot any approach, which presumably includes the visual and preserves the option of shooting a SIAP if you don't get the airport in sight, or the contact if the vis isn't quite good enough for the visual. As somebody who flies mostly in the New York area, I've never gotten a cruise clearance in my life, so I'm not really up on the details. What happens if I get "Cleared to the White Plains airport, via direct, cruise 3000, frequency change approved, have a nice night"? For the moment, let's assume it's 2:00 AM and the tower is closed. I plug HPN into my GPS, climb to 3000, and keep turning the little airplane icon until the track and bearing say the same number. Then what? I need 1000 and 3 to fly a visual. 30 miles out, I tune in the ATIS and hear that the weather is 2500 & 10. I'm currently in IMC. When do I begin my descent out of 3000 for the visual? I'm guessing I can't and must shoot an instrument approach? OK, I decided to shoot the GPS-34 (http://www.myairplane.com/databases/.../HPN_agr34.pdf). At what point do I stop going direct HPN and start heading to TUGME (the IAF)? And when do I begin my descent out of 3000? I'm guessing only once I pass TUGME, so let's assume that for the moment. So, I start on down from TUGME, and quickly break out right at 2500 and see the airport. Can I then change my mind about flying the GPS-34 and switch to the visual? I'm guessing I can, so I make a right turn, heading 000, to get lined up for a straight-in to 29 (my preferred runway since it puts me closest to my parking spot). Halfway to the airport, I discover I made a poor choice in breaking off the GPS approach because suddenly I find myself in a rain shower and quickly after that, back in IMC at 2000. I'm not worried about terrain in the immediate vicinity because I know I'm above anything close, but I figure a climb back to the MSA makes sense anyway, so I do that. Now what? If I decide to climb to 3000 and head back to TUGME for another GPS approach, am I still operating within my cruise clearance? I guess the gist of my question is, does the cruise clearance let me fly a single approach, or does it let me stooge around in the vicinity of the airport trying multiple approaches until I get in or give up? |
![]() Roy Smith wrote: As somebody who flies mostly in the New York area, I've never gotten a cruise clearance in my life, And you won't in that airspace. so I'm not really up on the details. What happens if I get "Cleared to the White Plains airport, via direct, cruise 3000, frequency change approved, have a nice night"? For the moment, let's assume it's 2:00 AM and the tower is closed. You go to White Plains, staying between the MEA and 3000 until you see the airport or get to a fix on an approach, shoot the approach and cancel like at any nontowered airport. I need 1000 and 3 to fly a visual. 30 miles out, I tune in the ATIS and hear that the weather is 2500 & 10. I'm currently in IMC. When do I begin my descent out of 3000 for the visual? I'm guessing I can't and must shoot an instrument approach? Yes. OK, I decided to shoot the GPS-34 (http://www.myairplane.com/databases/.../HPN_agr34.pdf). At what point do I stop going direct HPN and start heading to TUGME (the IAF)? Whenever you want. And when do I begin my descent out of 3000? When you are established on the approach as per the plate. So, I start on down from TUGME, and quickly break out right at 2500 and see the airport. Can I then change my mind about flying the GPS-34 and switch to the visual? Yes. I'm guessing I can, so I make a right turn, heading 000, to get lined up for a straight-in to 29 (my preferred runway since it puts me closest to my parking spot). Halfway to the airport, I discover I made a poor choice in breaking off the GPS approach because suddenly I find myself in a rain shower and quickly after that, back in IMC at 2000. I'm not worried about terrain in the immediate vicinity because I know I'm above anything close, but I figure a climb back to the MSA makes sense anyway, so I do that. Now what? Pick another approach and do it. If I decide to climb to 3000 and head back to TUGME for another GPS approach, am I still operating within my cruise clearance? Yes. I guess the gist of my question is, does the cruise clearance let me fly a single approach, or does it let me stooge around in the vicinity of the airport trying multiple approaches until I get in or give up? You can do whatever you want until you land or give up. |
Roy Smith wrote
What happens if I get "Cleared to the White Plains airport, via direct, cruise 3000, frequency change approved, have a nice night"? For the moment, let's assume it's 2:00 AM and the tower is closed. Well, I doubt you would ever get that at HPN (even at night, the area is pretty busy) but something like that has been known to happen at Huntsville (UTS) where 2200 is a perfectly valid IFR altitude but RADAR coverage below about 4000 just won't happen. I like to take students there (assuming their airplanes are fast enough to make the trip worthwhile) when we have a stratus layer, just so they can get that "You are on your own" feeling, and understand what it's like to do the full approach (and maybe the full missed approach) without being able to talk to anyone. Anyway, my point is that I know what it's like to be cut loose 30 miles from the airport, even if I never have heard the magic word (cruise) because out here it is done. If you pull up the VOR-DME A approach for UTS (http://www.myairplane.com/databases/.../UTS_vd_gA.pdf) you will note that it has 3 IAF's. Out there, you don't normally get a clearance to one of them - you get a clearance for the approach. Right away that should trip an alarm - the exact route is undefined! What this means in practice is this - the controller doesn't care. He's perfectly happy to block out a huge chunk of airspace for you, because nobody else wants it. I need 1000 and 3 to fly a visual. 30 miles out, I tune in the ATIS and hear that the weather is 2500 & 10. I'm currently in IMC. When do I begin my descent out of 3000 for the visual? I'm guessing I can't and must shoot an instrument approach? Why not? Your clearance is good for any altitude between 3000 and the minimum applicable IFR altitude. As long as you can assure that you will comply with 91.177, you may descend at your discretion. If you're on a random route, all you need is 1000 ft above obstacles within 4 nm (since the terrain is not mountainous). If you're on an airway, HPN is well within 22nm of CMK, and the MOCA's are all lower than 3000. That's the whole point of a cruise clearance - you own everything from 3000 on down. OK, I decided to shoot the GPS-34 (http://www.myairplane.com/databases/.../HPN_agr34.pdf). At what point do I stop going direct HPN and start heading to TUGME (the IAF)? At any point. You are the only guy around. Nobody else is using the airspace, or you would never have gotten that clearance. Just make sure that you can comply with 91.177 on your random route without exceeding 3000. And when do I begin my descent out of 3000? I'm guessing only once I pass TUGME, so let's assume that for the moment. Well, see above. Maybe yes, maybe no. So, I start on down from TUGME, and quickly break out right at 2500 and see the airport. Can I then change my mind about flying the GPS-34 and switch to the visual? I'm guessing I can, so I make a right turn, heading 000, to get lined up for a straight-in to 29 (my preferred runway since it puts me closest to my parking spot). Sounds good to me so far. Halfway to the airport, I discover I made a poor choice in breaking off the GPS approach because suddenly I find myself in a rain shower and quickly after that, back in IMC at 2000. I'm not worried about terrain in the immediate vicinity because I know I'm above anything close, but I figure a climb back to the MSA makes sense anyway, so I do that. No problem. MSA is 3000 and your clearance is to cruise 3000. Since you never reported vacating 3000, it's still yours. Now what? If I decide to climb to 3000 and head back to TUGME for another GPS approach, am I still operating within my cruise clearance? Well, since you have yet to complete an approach, I can't see why not. I guess the gist of my question is, does the cruise clearance let me fly a single approach, or does it let me stooge around in the vicinity of the airport trying multiple approaches until I get in or give up? I would think the latter. Remember, you got that clearance because you're the only idiot flying around there. You were given a big block of airspace, and you own it until you either cancel IFR or report that you can't get in and need to do something else. Michael |
![]() "Michael" wrote in message om... OK, now ask yourself why you weren't issued a cruise clearance, when that's the legal way of accomplishing what you both want. Some suggested answers: (a) The controller is ornery and likes breaking the rules (b) The controller doesn't care about rules and can't be bothered to do anything differently. (c) The controller doesn't believe in cruise clearances (d) The controller doesn't know about cruise clearances Which do YOU think is correct? d |
![]() "Michael" wrote in message om... (Snowbird) wrote Well, there isn't an SIAP and IIRC one can't fly a contact approach to an airport without an SIAP. You recall correctly. The visual is the only choice here. But otherwise, I think you've got a great point. A cruise clearance would accomplish exactly what we both want, and be perfectly legal. OK, now ask yourself why you weren't issued a cruise clearance, when that's the legal way of accomplishing what you both want. Some suggested answers: (a) The controller is ornery and likes breaking the rules (b) The controller doesn't care about rules and can't be bothered to do anything differently. (c) The controller doesn't believe in cruise clearances (d) The controller doesn't know about cruise clearances Which do YOU think is correct? I say "d" with a twist: The controller knows there is something in the book about a cruise clearance, but doesn't know how a cruise clearance works. This seems most likely to me, since the controller also doesn't know how a visual approach works either... Chip, ZTL |
Report Leaving Assigned Altitude? | John Clonts | Instrument Flight Rules | 81 | March 20th 04 02:34 PM |
Night over water | Stuart King | Instrument Flight Rules | 43 | March 4th 04 01:13 AM |
Completing the Non-precision approach as a Visual Approach | John Clonts | Instrument Flight Rules | 45 | November 20th 03 05:20 AM |
Visual Appr. | Stuart King | Instrument Flight Rules | 15 | September 17th 03 08:36 PM |
