Roy Smith wrote
What happens if I get "Cleared to the White Plains airport, via direct, cruise 3000, frequency change approved, have a nice night"? For the moment, let's assume it's 2:00 AM and the tower is closed. Well, I doubt you would ever get that at HPN (even at night, the area is pretty busy) but something like that has been known to happen at Huntsville (UTS) where 2200 is a perfectly valid IFR altitude but RADAR coverage below about 4000 just won't happen. I like to take students there (assuming their airplanes are fast enough to make the trip worthwhile) when we have a stratus layer, just so they can get that "You are on your own" feeling, and understand what it's like to do the full approach (and maybe the full missed approach) without being able to talk to anyone. Anyway, my point is that I know what it's like to be cut loose 30 miles from the airport, even if I never have heard the magic word (cruise) because out here it is done. If you pull up the VOR-DME A approach for UTS (http://www.myairplane.com/databases/.../UTS_vd_gA.pdf) you will note that it has 3 IAF's. Out there, you don't normally get a clearance to one of them - you get a clearance for the approach. Right away that should trip an alarm - the exact route is undefined! What this means in practice is this - the controller doesn't care. He's perfectly happy to block out a huge chunk of airspace for you, because nobody else wants it. I need 1000 and 3 to fly a visual. 30 miles out, I tune in the ATIS and hear that the weather is 2500 & 10. I'm currently in IMC. When do I begin my descent out of 3000 for the visual? I'm guessing I can't and must shoot an instrument approach? Why not? Your clearance is good for any altitude between 3000 and the minimum applicable IFR altitude. As long as you can assure that you will comply with 91.177, you may descend at your discretion. If you're on a random route, all you need is 1000 ft above obstacles within 4 nm (since the terrain is not mountainous). If you're on an airway, HPN is well within 22nm of CMK, and the MOCA's are all lower than 3000. That's the whole point of a cruise clearance - you own everything from 3000 on down. OK, I decided to shoot the GPS-34 (http://www.myairplane.com/databases/.../HPN_agr34.pdf). At what point do I stop going direct HPN and start heading to TUGME (the IAF)? At any point. You are the only guy around. Nobody else is using the airspace, or you would never have gotten that clearance. Just make sure that you can comply with 91.177 on your random route without exceeding 3000. And when do I begin my descent out of 3000? I'm guessing only once I pass TUGME, so let's assume that for the moment. Well, see above. Maybe yes, maybe no. So, I start on down from TUGME, and quickly break out right at 2500 and see the airport. Can I then change my mind about flying the GPS-34 and switch to the visual? I'm guessing I can, so I make a right turn, heading 000, to get lined up for a straight-in to 29 (my preferred runway since it puts me closest to my parking spot). Sounds good to me so far. Halfway to the airport, I discover I made a poor choice in breaking off the GPS approach because suddenly I find myself in a rain shower and quickly after that, back in IMC at 2000. I'm not worried about terrain in the immediate vicinity because I know I'm above anything close, but I figure a climb back to the MSA makes sense anyway, so I do that. No problem. MSA is 3000 and your clearance is to cruise 3000. Since you never reported vacating 3000, it's still yours. Now what? If I decide to climb to 3000 and head back to TUGME for another GPS approach, am I still operating within my cruise clearance? Well, since you have yet to complete an approach, I can't see why not. I guess the gist of my question is, does the cruise clearance let me fly a single approach, or does it let me stooge around in the vicinity of the airport trying multiple approaches until I get in or give up? I would think the latter. Remember, you got that clearance because you're the only idiot flying around there. You were given a big block of airspace, and you own it until you either cancel IFR or report that you can't get in and need to do something else. Michael |
Report Leaving Assigned Altitude? | John Clonts | Instrument Flight Rules | 81 | March 20th 04 02:34 PM |
Night over water | Stuart King | Instrument Flight Rules | 43 | March 4th 04 01:13 AM |
Completing the Non-precision approach as a Visual Approach | John Clonts | Instrument Flight Rules | 45 | November 20th 03 05:20 AM |
Visual Appr. | Stuart King | Instrument Flight Rules | 15 | September 17th 03 08:36 PM |
