FWIW, I have been chewed out by Seattle Approach for intercepting higher
than the published GSIA of 2200 for the ILS 13R. wrote in message oups.com... Hello, Yesterday I was out getting an IPC. We were doing the Stockton, CA ILS. ATC had us intercepting the localizer at 2000 feet. The altitude for glideslope interception is 1800 ( underlined ). My old CFII taught me that the glideslope interception altitude on the chart is a minimum altitude, and that it was fine to intercept it higher. So I just tootled along at 2000 - figuring it was simpler to do one configuration change at GS interception rather than three changes - one to descend the 200 feet, another to level off, and a third to intercept the glideslope. The new CFII criticized this procedure and told me that the plate specified 1800, and it was wrong to intercept at 2000. Which one was right? - Jerry Kaidor ( ) |
In article , Bob Gardner
wrote: FWIW, I have been chewed out by Seattle Approach for intercepting higher than the published GSIA of 2200 for the ILS 13R. For which airport? |
wrote: FWIW, I have been chewed out by Seattle Approach for intercepting higher than the published GSIA of 2200 for the ILS 13R. Nevermind the "Which airport" question if my cancel didn't work, I found it; Boeing field, I assume. I can't see why they would have chewed you out -- if the instruction was something like "Maintain 2500 until established on the localizer, cleared the ILS 13R," you did nothing improper. If he wanted you at 2200, he should have instructed you to do so; the chart only lists it as a minimum altitude, as most do. What if you weren't DME-equipped? How would you know you were within 10NM of NOLLA, and thus safe to descend to 2200? You really wouldn't, unless you had done the procedure turn, or the controller had cleared you with a "You're X miles from NOLLA" (and X happened to be less than 10 miles). -- Garner R. Miller ATP/CFII/MEI Clifton Park, NY =USA= http://www.garnermiller.com/ |
We intercepted at 3000 and rode it down more out of inertia than anything
else. We did have a "maintain 2200" instruction while at three but not a "descend and maintain." As I recall, I was coming from the northwest and had picked up the localizer 20 miles or so out. Three is pretty popular around here for the lowest altitude prior to an approach, and in retrospect I think the controller just wanted me to make a hole for someone else to fit into. Gotta admit I felt a little sheepish about getting called on it because I knew better. "Garner Miller" wrote in message ... In article , Bob Gardner wrote: FWIW, I have been chewed out by Seattle Approach for intercepting higher than the published GSIA of 2200 for the ILS 13R. Nevermind the "Which airport" question if my cancel didn't work, I found it; Boeing field, I assume. I can't see why they would have chewed you out -- if the instruction was something like "Maintain 2500 until established on the localizer, cleared the ILS 13R," you did nothing improper. If he wanted you at 2200, he should have instructed you to do so; the chart only lists it as a minimum altitude, as most do. What if you weren't DME-equipped? How would you know you were within 10NM of NOLLA, and thus safe to descend to 2200? You really wouldn't, unless you had done the procedure turn, or the controller had cleared you with a "You're X miles from NOLLA" (and X happened to be less than 10 miles). -- Garner R. Miller ATP/CFII/MEI Clifton Park, NY =USA= http://www.garnermiller.com/ |
![]() "Bob Gardner" wrote in message news ![]() FWIW, I have been chewed out by Seattle Approach for intercepting higher than the published GSIA of 2200 for the ILS 13R. What was your clearance? |
