Since this topic is being beat into submission as usual, I'll
add a pet peeve of a lot of controllers I know, myself included: N1234: "airport in sight" controller: "cleared visual approach" N1234: "roger, we'll cancel IFR" This happens daily, why? What is the point in reporting the airport and a) not requesting the visual, if it's wanted, or, b) canceling in the first transmission if the visual isn't wanted? Someone brought up wasted transmissions, there's an example. Speaking of wasted transmissions, and someone used the example of five transmissions to get the Visual approach sequence rolling, the controller who will be issuing the approach should on initial call-in advise of what to expect. This should make it clearer and what's expected of the pilot later. Example: "N1234, expect visual runway 25, advise when you have atis Xray and the airport in sight" (technically now I guess we have to say the name of the airport and it's position - is it done? not often) Anyway, that transmission sure shouldn't leave much doubt in anyone's mind. It's also a good time if the pilot is requesting something other than that. Cruise Clearances: the reason it's not used much and rarely offered, here anyway, is terrain and radio/radar coverage. It's basically a block altitude from whatever you give away, to the ground, and if it doesn't work out, back up to whatever altitude you assign. That's one hell of a chunk of airspace to lock up. And you are never sure how long you are really giving it away for as you may not hear the aircraft cancel. Also things not used often or on a regular basis, controllers get rusty on, let's be honest. Contact Approaches: Read last sentence, just not requested enough and pilots and controllers both get rusty on it. Example: had a guy ask for one at an airport with no SIAP, another one asked for one where the tower said they were totally IFR less than a mile visibility, virtually impossible to accomplish. On the controller side, you'll see the "standby" as they ask their supervisor if/how to do it. Some observations, Chris |
On Thu, 15 Apr 2004 06:48:17 GMT, "SeeAndAvoid"
wrote: "N1234, expect visual runway 25, advise when you have atis Xray and the airport in sight" Why not just: "N5843Q, expect visual runway 32"? It's shorter and conveys the same information and (implied) request. Even better is when the "visual" is on an ATIS, if available. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
"Ron Rosenfeld" wrote
"N1234, expect visual runway 25, advise when you have atis Xray and the airport in sight" Why not just: "N5843Q, expect visual runway 32"? It's shorter and conveys the same information and (implied) request. It may be shorter, but we are required to know the other two items: that you have the current weather (atis) and that you have the airport in sight. Even better is when the "visual" is on an ATIS, if available. Can skip that info if pilot advises he has the ATIS, but since the rule says the controller shall advise of the approach on initial contact or as soon as possible thereafter, the pilot has to advise of the ATIS on his initial contact. Most airports I do approaches to dont have an ATIS, so it's a moot point. See 7110.65 Par 4-7-10 http://www.faa.gov/atpubs/ATC/Chp4/atc0407.html#4-7-1 4-7-10. APPROACH INFORMATION a. Both en route and terminal approach control sectors shall provide current approach information to aircraft destined to airports for which they provide approach control services. This information shall be provided on initial contact or as soon as possible thereafter. Approach information contained in the ATIS broadcast may be omitted if the pilot states the appropriate ATIS code or items 3-5 below may be omitted for pilots destined to uncontrolled airports when they advise receipt of the automated weather; otherwise, issue approach information by including the following: 1. Approach clearance or type approach to be expected if two or more approaches are published and the clearance limit does not indicate which will be used. 2. Runway if different from that to which the instrument approach is made. 3. Surface wind. 4. Ceiling and visibility if the reported ceiling at the airport of intended landing is below 1,000 feet or below the highest circling minimum, whichever is greater, or the visibility is less than 3 miles. 5. Altimeter setting for the airport of intended landing. Chris |
![]() "SeeAndAvoid" wrote in message link.net... It may be shorter, but we are required to know the other two items: that you have the current weather (atis) and that you have the airport in sight. How are you going to know the current weather at fields without weather reporting? Can skip that info if pilot advises he has the ATIS, but since the rule says the controller shall advise of the approach on initial contact or as soon as possible thereafter, the pilot has to advise of the ATIS on his initial contact. Most airports I do approaches to dont have an ATIS, so it's a moot point. See 7110.65 Par 4-7-10 http://www.faa.gov/atpubs/ATC/Chp4/atc0407.html#4-7-1 4-7-10. APPROACH INFORMATION a. Both en route and terminal approach control sectors shall provide current approach information to aircraft destined to airports for which they provide approach control services. This information shall be provided on initial contact or as soon as possible thereafter. Approach information contained in the ATIS broadcast may be omitted if the pilot states the appropriate ATIS code or items 3-5 below may be omitted for pilots destined to uncontrolled airports when they advise receipt of the automated weather; otherwise, issue approach information by including the following: 1. Approach clearance or type approach to be expected if two or more approaches are published and the clearance limit does not indicate which will be used. 2. Runway if different from that to which the instrument approach is made. 3. Surface wind. 4. Ceiling and visibility if the reported ceiling at the airport of intended landing is below 1,000 feet or below the highest circling minimum, whichever is greater, or the visibility is less than 3 miles. 5. Altimeter setting for the airport of intended landing. I'm going to an uncontrolled field without weather reporting. How are you going to comply with that paragraph? |
We have some airports that have AWOS, but we don't get any of
that info into our computer, but the pilot can receive it. We have a couple that we have no weather reporting, but the pilot can get it from their company on the ground, and they let us know. And theres a couple that MAYBE they can get someone to answer unicom and get the weather. There are only a few left I can think of that have no SIAP, no AWOS, and lucky to have anything living within 20nm of it. Those pilots usually know what they are dealing with way in advance and have done it regularly and cancel way out. They arent going to get a contact approach, those are the ones that will on occasion ask for a cruise clearance, but those are also airports with sometimes no phones and no cellular coverage. In the end it's up to the pilot to get the weather, and if it's not available we have to advise them of that, too. Luckily the weather at those airports are VFR probably 350 days out of the year, but talk about remote. One guy called from a phonebooth, needed a clearance, but also time to drive back to the airport (30mins away), get started and go. A couple have recently worked out private approaches and someone available on the ground associated with the airplane to get them the weather, Lifeguard flights usually, with an employee of the hospital nearby giving them the conditions. Chris "Steven P. McNicoll" wrote in message ink.net... "SeeAndAvoid" wrote in message link.net... It may be shorter, but we are required to know the other two items: that you have the current weather (atis) and that you have the airport in sight. How are you going to know the current weather at fields without weather reporting? Can skip that info if pilot advises he has the ATIS, but since the rule says the controller shall advise of the approach on initial contact or as soon as possible thereafter, the pilot has to advise of the ATIS on his initial contact. Most airports I do approaches to dont have an ATIS, so it's a moot point. See 7110.65 Par 4-7-10 http://www.faa.gov/atpubs/ATC/Chp4/atc0407.html#4-7-1 4-7-10. APPROACH INFORMATION a. Both en route and terminal approach control sectors shall provide current approach information to aircraft destined to airports for which they provide approach control services. This information shall be provided on initial contact or as soon as possible thereafter. Approach information contained in the ATIS broadcast may be omitted if the pilot states the appropriate ATIS code or items 3-5 below may be omitted for pilots destined to uncontrolled airports when they advise receipt of the automated weather; otherwise, issue approach information by including the following: 1. Approach clearance or type approach to be expected if two or more approaches are published and the clearance limit does not indicate which will be used. 2. Runway if different from that to which the instrument approach is made. 3. Surface wind. 4. Ceiling and visibility if the reported ceiling at the airport of intended landing is below 1,000 feet or below the highest circling minimum, whichever is greater, or the visibility is less than 3 miles. 5. Altimeter setting for the airport of intended landing. I'm going to an uncontrolled field without weather reporting. How are you going to comply with that paragraph? |
"SeeAndAvoid" wrote:
One guy called from a phonebooth, needed a clearance, but also time to drive back to the airport (30mins away), get started and go. I believe it's a TERPS requirement that to have an approach you need to have a working and publicly accessable landline phone on the field. Don't know anything about departures, though :-) I once got into a ****ing contest with Verizon (they were probably calling themselves Bell Atlantic back then) when they tore the only public phone out of a small airport around here because it wasn't generating enough revenue. I had gone to call for a clearance and found the booth still there, but wires just hanging out where there used to be a phone. I talked to everybody I could think of (the Public Service Commission, the FSDO, the airport manager, NY Tracon, AOPA, etc). Nobody seemed too worried about it. |
![]() "SeeAndAvoid" wrote in message link.net... We have some airports that have AWOS, but we don't get any of that info into our computer, but the pilot can receive it. We have a couple that we have no weather reporting, but the pilot can get it from their company on the ground, and they let us know. And theres a couple that MAYBE they can get someone to answer unicom and get the weather. There are only a few left I can think of that have no SIAP, no AWOS, and lucky to have anything living within 20nm of it. Those pilots usually know what they are dealing with way in advance and have done it regularly and cancel way out. They arent going to get a contact approach, those are the ones that will on occasion ask for a cruise clearance, but those are also airports with sometimes no phones and no cellular coverage. In the end it's up to the pilot to get the weather, and if it's not available we have to advise them of that, too. Luckily the weather at those airports are VFR probably 350 days out of the year, but talk about remote. One guy called from a phonebooth, needed a clearance, but also time to drive back to the airport (30mins away), get started and go. A couple have recently worked out private approaches and someone available on the ground associated with the airplane to get them the weather, Lifeguard flights usually, with an employee of the hospital nearby giving them the conditions. What about those fields with SIAPs but no weather reporting at all? |
On Thu, 15 Apr 2004 14:27:41 GMT, "SeeAndAvoid"
wrote: "Ron Rosenfeld" wrote "N1234, expect visual runway 25, advise when you have atis Xray and the airport in sight" Why not just: "N5843Q, expect visual runway 32"? It's shorter and conveys the same information and (implied) request. It may be shorter, but we are required to know the other two items: that you have the current weather (atis) and that you have the airport in sight. Oops, I overlooked the ATIS in your initial callup and I agree that if the pilot does not report it, that you should request it. I was always taught to advise the controller on my initial callup that I have the ATIS. But, it is frequent for me to be asked if I have the ATIS even when I have just called in reporting that I DO have the ATIS! So far as the other, the pilot should know that he has to report the airport (or preceding a/c) in sight in order to get the visual. So when you say "expect", that primes me to report the airport in sight. Most airports I do approaches to dont have an ATIS, so it's a moot point. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
Do you say you have "the ATIS" or do you say you have the
appropriate/current ATIS code. Makes a difference to the controller. JPH Ron Rosenfeld wrote: On Thu, 15 Apr 2004 14:27:41 GMT, "SeeAndAvoid" wrote: "Ron Rosenfeld" wrote "N1234, expect visual runway 25, advise when you have atis Xray and the airport in sight" Why not just: "N5843Q, expect visual runway 32"? It's shorter and conveys the same information and (implied) request. It may be shorter, but we are required to know the other two items: that you have the current weather (atis) and that you have the airport in sight. Oops, I overlooked the ATIS in your initial callup and I agree that if the pilot does not report it, that you should request it. I was always taught to advise the controller on my initial callup that I have the ATIS. But, it is frequent for me to be asked if I have the ATIS even when I have just called in reporting that I DO have the ATIS! So far as the other, the pilot should know that he has to report the airport (or preceding a/c) in sight in order to get the visual. So when you say "expect", that primes me to report the airport in sight. Most airports I do approaches to dont have an ATIS, so it's a moot point. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
Report Leaving Assigned Altitude? | John Clonts | Instrument Flight Rules | 81 | March 20th 04 02:34 PM |
Night over water | Stuart King | Instrument Flight Rules | 43 | March 4th 04 01:13 AM |
Completing the Non-precision approach as a Visual Approach | John Clonts | Instrument Flight Rules | 45 | November 20th 03 05:20 AM |
Visual Appr. | Stuart King | Instrument Flight Rules | 15 | September 17th 03 08:36 PM |
