DG-300 Wing fore/aft pin slop
Old January 27th 06, 06:05 PM posted to rec.aviation.soaring
Default DG-300 Wing fore/aft pin slop
I own an 1985 DG-300 3e127 with 1350 hrs. I too have a sizeable gap
between the wings and fuse (~1/8") after assembly. However, my wings
have virtually no freeplay or movement at the tips. The maintenance
manual does call for installing shim washers on the pin(s) when there
is freeplay (sec 1.10). With the amount of motion you describe I would
get it looked at. After consulting with your local A&I you could
contact DG's service dept via email for washers (and/or specifications
on max allowable freeplay). They have always been very helpful for me.
John Cotter (XJ)
Grob G102 Setup BDS Soaring 11 August 30th 05 03:42 PM
Props and Wing Warping... was soaring vs. flaping Wright1902Glider Home Built 0 September 29th 03 03:40 PM
An Affordable Homebrue 60 in DS machine Grant Soaring 0 August 8th 03 03:52 AM
