How Quickly Things Can Turn!
Old January 27th 06, 07:20 PM posted to rec.aviation.ifr
Default How Quickly Things Can Turn!
"three-eight-hotel" wrote in message
I don't think it would have been considered VFR in IMC... There were
absolutely no clouds (although clouds aren't what constitute IMC), and
at 3,000 feet I had constant visual reference with the ground and never
had to depend on my instruments for navigation or situational
awareness. I probably had visibility of 2-3 miles through the haze,
But as you know, less than 3 sm visibility is IMC (except in Class G during
the day at 1200' AGL or less), so VFR flight in those conditions is unsafe
and illegal.
You described being able to see things "down" but not "at a slant" in haze
at 3000'. At that altitude, if you can't see prominent objects 11 degrees
below horizontal, you have less than 3 sm visibility (and if you can't see
prominent objects 35 degrees below horizontal--still nowhere near
"down"--you have less than 1sm visibility).
Even if you can manage to aviate and navigate without instruments while
flying VFR in IMC, you don't have adequate means to see and avoid anyone
who's legally flying IFR near you. So you're betting their lives that you
won't happen to collide with them.
reason to post was
walking outside after dinner and seeing an entirely different weather
picture than I had seen only an hour ago, when I landed.
I appreciate your motivation for posting, but I think you've overlooked a
far more important lesson than the one you had in mind.
Regards,
Gary
Old January 27th 06, 08:08 PM posted to rec.aviation.ifr
and illegal.
Agreed.
Any typical day in the Sacramento Valley is going to involve haze,
except for those perfect days. I am certain that I have flown in
conditions of 10, 20+, to almost unlimited visibility, where I couldn't
see Mt. Diable, 90ish miles away, at an altitude that probably put it
at 11 degrees below horizontal.
Standing on the ground at the departure and destination airports, I can
comfortably say that there was 5 sm visibility, as I was amazed at how
different things could look from the ground and in the air. An
un-intentionally omitted fact was that the flight occured around 4:30
p.m., which added another parameter, being the setting sun. The
setting sun and haze could have likely made for poorer visibility, as
I was flying East to West???
Another fact that I will humbly admit to, is that my gauge of distance
probably leaves a lot to be desired. I welcome any and all comments to
how people best gauge distance. I would like to know that when I
report a 5 mile final, it isn't actually a 7 mile final, which I
suspect I might be guilty of.
I'm certainly not trying to be argumentative and appreciate your post,
nor am I looking to get flamed for flying VFR into IMC, which I assure
you, I would not be comfortable doing or be happy about, if I had let
it occur.
As I said above, the visibilty on the ground, after arrival, I would
comfortably call 5 miles. Although I'd feel better about stating that,
if I could see a copy of the METAR for that time. Is there any way of
finding METAR information for a previous day??? It would be nice to
see a copy for peace of mind...
Thanks Gary! Your point is taken! I "did" take a 10 minute flight for
granted, and will no longer depend on a forecast and a pop-up and see
how it feels report for current weather. I will "always" get a
breifing at least one hour prior to departure. The other point in
that, is that there could have been a situation where a temporary TFR
was introduced since the original briefing...
Best Regards,
Todd
Old January 27th 06, 10:46 PM posted to rec.aviation.ifr
"three-eight-hotel" wrote in message ups.com...
Todd
http://adds.aviationweather.gov/metars/
Enter the aerodrome identifier, and select the time period, up to 36 hours,
from the drop-down box.
Old January 30th 06, 06:18 PM posted to rec.aviation.ifr
Thanks John! That's very useful, within the 36 hour window, as you
mentioned.
Old January 27th 06, 11:39 PM posted to rec.aviation.ifr
haze
degrees
see
Of course--it varies with altitude. At 3000', 11 degrees below horizontal
gives you just under 3 sm slant distance. At a much higher altitude, 11
degrees below horizontal gives a much greater slant distance.
Quite likely. But flight visibility is defined by how far you can see,
regardless of the factors that contribute to limiting that distance. And the
VMC/IMC visibility distinction is defined with regard to *flight*
visibility, not ground visibility.
Yup, it's hard to judge distance, especially when the air is very hazy.
Calculating the slant distances that correspond to various altitudes and
viewing angles can be helpful. An obvious easy one to remember is that at 30
degrees below horizontal, the slant distance is twice your altitude
(neglecting earth curvature).
it occur.
I believe you. But with no flame intended, and with all due respect, your
description (seeing things in the down direction, but not at much of a
slant, from 3000') makes it seem likely that your flight visibility was
*nowhere near* VMC. In fact, if you couldn't see prominent objects from your
altitude 35 degrees below horizontal, the conditions were not only IFR but
LIFR! (Of course, all this applies when you are *in* the haze rather than
*above* the haze.)
you
But that's what not defines the difference between VMC and IMC. What matters
is *flight* visibility, which (as your story vividly illustrates) can be
much less than ground visibility. And it makes sense that the rules refer to
flight visibility, because a primary reason not to be VFR in IMC is the need
to see and avoid other aircraft--and that ability depends on your flight
visibility. (Again, my intent here is not to criticize, but to
constructively point out a vital distinction that you and perhaps other
pilots here may have forgotten.)
That's a good idea too, but the same situation could well have arisen even
with a more up-to-date briefing. Once you take off and discover sub-VMC
flight visibility, the briefing becomes moot.
You might want to file an ASRS report on this flight--not only for your
legal protection (most likely no one noticed anyway), but also because this
is exactly the sort of event that NASA hopes to learn from in order to
improve aviation safety. As do the readers of this newsgroup, so thanks for
your post!
Regards,
Gary
Old January 30th 06, 02:20 PM posted to rec.aviation.ifr
three-eight-hotel wrote:
Is there any way of
http://www.uswx.com/us/stn/?code=d&n=24&stn=kRDU
http://weather.noaa.gov/
Old January 30th 06, 06:17 PM posted to rec.aviation.ifr
Perfect! Thanks!
Procedure turn required? Peter Duniho Instrument Flight Rules 80 July 6th 05 08:12 PM
What's considered a steep turn by the airlines? Bob Chilcoat Piloting 3 June 23rd 05 03:59 PM
IFR in the 1930's Del Rawlins Owning 33 September 11th 03 07:42 PM
IR checkride story! Guy Elden Jr. Instrument Flight Rules 16 August 1st 03 09:03 PM
