Don't try this with Atlas Jay
Old January 26th 06, 08:02 PM posted to rec.aviation.piloting
Default Don't try this with Atlas Jay
Leonard wrote:
I take it you guys are not helicopter pilots. I didn't see anything all
that scary in the video although some of it would have been far too
dangerous in most any airplane for my tastes.
No Leonard, we're not even plank drivers, we have rickshaws that we
pull around on the streets of Vietnam. We actually make good money
doing this, 30-40 Dongs a day. Enough to buy a big bowl of Pho. We
just come here to RAP to pretend we're pilots.
The Monk
Old January 26th 06, 08:18 PM posted to rec.aviation.piloting
"Flyingmonk"
No Leonard, we're not even plank drivers, we have rickshaws that we pull
around on the streets of Vietnam. We actually make good money doing this,
30-40 Dongs a day. Enough to buy a big bowl of Pho. We just come here
Different cultures:
We say, "Money! Cha-ching." ...while they say, "Money! Ding-dong."
Montblack
Old January 26th 06, 10:17 PM posted to rec.aviation.piloting
"Leonard Ellis" wrote in message
m...
Cheers,
Leonard
Most of it didn't look all that bad, as I understand it, you can autorotate
if you have speed even if you don't have altitude. But how would you
autorotate if you are hoovering with your nose 50 feet away from a cliff?
Pull the cyclic back and do it in reverse?
You are right - at least I'm not a helicopter pilot - so I don't have a clue
if it is easy or impossible..
Geoff
the sea hawk at wow way d0t com
Spell checking is left as an excercise for the reader.
Old January 27th 06, 10:44 PM posted to rec.aviation.piloting
Yes, so long as the aircraft has sufficient altitude, one can recover
sufficient airspeed [really, kinetic energy in the rotor system], even with
an initial slide to the rear if you let the fuselage turn in the same
direction as the rotors, to perform a successful autorotation. However,
there is an area in the flight envelope of every helicopter we called "the
dead man zone" within which a successful autorotation is very unlikely or
impossible. Hovering or flying at low airspeed within a few feet of a cliff
face is no big deal if not operating within the dead man's zone for that
aircraft.
During RVN, I suffered a total engine failure (N1 compressor ate itself) at
very low altitude, thankfully at a high enough airspeed (~100 Kt), in a Huey
(UH-1H) from which the textbook recovery worked perfectly: slight popup,
bottom the pitch, hard flare to rebuild rotor rpm while killing forward
motion and finally use the rotor system's stored energy to cushion the
machine onto the ground. It helps if you happen to be flying into the wind
at the moment of power loss.
I expect that most crashes from low altitude and high airspeeds in
helicopters to usually be the consequence of flying into something which
swats the machine from the air or from some sort of loss of control induced
by pilot control input, weather/wind, combat damage, or mechanical failure.
One can do that sort of thing in any sort of flying machine, eh?
I know that even in normal and cautious operation of our Skyhawk, there are
times when I'm flying the aircraft in situations which are probably not 100%
survivable in every circumstance, such as total power loss during an ILS
approach to an airport which has extended over water exposure on the final.
For that matter, driving around in my wife's Volvo isn't 100% safe, although
it is probably at least marginally safer than my Mazda MX-5 roadster.
Cheers,
Leonard
"Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote in message
m...
Cheers,
Leonard
autorotate if you have speed even if you don't have altitude. But how
would you autorotate if you are hoovering with your nose 50 feet away from
a cliff? Pull the cyclic back and do it in reverse?
clue if it is easy or impossible..
Geoff
Old January 28th 06, 12:34 AM posted to rec.aviation.piloting
On Fri, 27 Jan 2006 22:44:17 GMT, "Leonard Ellis"
really good stuff snipped here
Thanks for the post.
You put many things into a perspective that many young pilots don't
seem to grasp. Your writing and insights should be required reading
for them.
Please keep it up.
Mike Weller
Atlas is down... Jay Honeck Owning 42 January 17th 06 01:47 PM
Atlas Air update of registrations ellx Instrument Flight Rules 0 January 8th 05 05:00 PM
Atlas Air N-522-MC will be back into LUX. ellx General Aviation 0 January 4th 05 07:47 PM
Atlas Air N-522-MC will be back into LUX. ellx Instrument Flight Rules 0 January 4th 05 07:47 PM
Atlas 2AS Launch tonight from Cape Canaveral AFS AllanStern Military Aviation 0 May 19th 04 10:32 PM
