We are procedurally in violent agreement. Nonetheless, the G/S is not
primary prior to the PFAF, any minimum altitude constraints notwithstanding. That is the legalese of Part 97. I am just the messenger. We're agreed that at SCK following the glide slope down from the 2000 foot vector altitude is the best procedure. We're also agreed that the G/S is not primary outside the PFAF. Instead, one must abide by the published altitudes - in this case we must remain above 1800 until this PFAF. At SCK, this is logically guaranteed by our "best procedure". However, I detect that your position is still that some sufficiently zealous FAA inspector could violate me for using the G/S to descend to 1800. (otherwise how could the new instructor be "technically correct"?). I disagree. If that is your position, please cite which verse of Part 97 that this zealous inspector could attempt to violate me on? Which regulation does our agreed best procedure not comply with? It's pointless discussing legality without reference to the law. |
I agree with everything you just wrote. But, you have not addressed
my question. In what way does/can following the glideslope from 2000 to 1800 feet at SCK violate the regulatory implications of the SCK ILS's 8260-3? There is no rule that says "thou shalt not follow the G/S unless it is primary". What the rules say is "thou shall not bust the published altitude restrictions prior to the PFAF". Since it isn't logically possible to violate the altitude restrictions *in this instance* by following the G/S, it can't be illegal to do so. The regulatory basis is 91.175(a) which requires "Unless otherwise authorized by the Administrator, when an instrument letdown to a civil airport is necessary, each person operating an aircraft, except a military aircraft of the United States, shall use a standard instrument approach procedure prescribed for the airport in part 97 of this chapter." Part 97 does not prescribe pilot technique. It prescribes the tracks and altitudes to be flown. If those are complied with, there's no possible violation. |
"In the specifics cited for Stockton there is no issue of legality."
We're agreed then. I had attempted to emphasize in my long series of messages to you that *I* was talking about Stockton, whatever might have been in the CFI's mind. Ed |
What I'm having difficulty reconciling is the following statements of
yours: "If you can receive the G/S prior to the PFAF, it's only advisory in any case, so you are free to use it as you choose, provided you don't violate any minimum segment altitude or stepdown fixes or any aspect of an ATC clearance." I totally agree. "The new CFI is technically correct but the old CFI is far more practical." "In the case cited, the CFI is nitpicking but is nonetheless legally correct." "I agree that the CFI is procedurally wrong, although legally correct." So how can you assert these, *given that in this instance* it is physically and logically impossible to "violate any minimum segment altitude or stepdown fixes or any aspect of an ATC clearance", because a) the ATC clearance was to maintain 2000 until intercepting the localizer, and b) the procedure was to descend on the glide slope to the minimum segment altitude (1800) at which point the G/S becomes primary. The point is that blindly following the glideslope has the potential at places *other than SCK* of causing violations of published altitudes. Following the G/S is not a violation per se, busting published or ATC assigned altitudes is. The CFI is not "technically correct" or "legally correct". What he could have said, after the flight, is that if one chooses to follow the G/S prior to the PFAF one needs to be mindful that published and ATC assigned altitudes have to be complied with, but that at SCK that was not an issue. |
If an altitude is underlined, it is the MINIMUM altitude...
if an altitude is over-lined it is the maximum altitude. If it is both under and over-lined the altitude is mandatory. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. wrote in message oups.com... | What I'm having difficulty reconciling is the following statements of | yours: | | "If you can receive the G/S prior to the PFAF, it's only advisory in | any | case, so you are free to use it as you choose, provided you don't | violate any minimum segment altitude or stepdown fixes or any aspect of | an ATC clearance." | | I totally agree. | | "The new CFI is technically correct but the old CFI is far more | practical." | "In the case cited, the CFI is nitpicking but is nonetheless legally | correct." | "I agree that the CFI is procedurally wrong, although legally correct." | | | So how can you assert these, *given that in this instance* it is | physically and logically impossible to "violate any minimum segment | altitude or stepdown fixes or any aspect of | an ATC clearance", because | a) the ATC clearance was to maintain 2000 until intercepting the | localizer, and | b) the procedure was to descend on the glide slope to the minimum | segment altitude (1800) at which point the G/S becomes primary. | | The point is that blindly following the glideslope has the potential | at places *other than SCK* of causing violations of published | altitudes. Following the G/S is not a violation per se, busting | published or ATC assigned altitudes is. | The CFI is not "technically correct" or "legally correct". What he | could have said, after the flight, is that if one chooses to follow the | G/S prior to the PFAF one needs to be mindful that published and ATC | assigned altitudes have to be complied with, but that at SCK that was | not an issue. | |
"Jim Macklin" wrote
If an altitude is underlined, it is the MINIMUM altitude... if an altitude is over-lined it is the maximum altitude. If it is both under and over-lined the altitude is mandatory. Jim, you've really got to make a better attempt at keeping up with these threads. Garner Miller posted this a few days back: 1800 is the minimum altitude; that's why it's underlined only on the bottom of the number on the NACO charts. If it were mandatory, it would have lines above and below (or the word "Mandatory" on Jepp charts), and you would have to go down to 1800. Bob Moore |
I would try to monitor these groups 24/7 but sleep and other
tasks get in the way. Some posts get lost, some are snipped, some don't include any of the previous post, sorry if I post something that has been covered before. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Bob Moore" wrote in message . 122... | "Jim Macklin" wrote | | If an altitude is underlined, it is the MINIMUM altitude... | if an altitude is over-lined it is the maximum altitude. If | it is both under and over-lined the altitude is mandatory. | | Jim, you've really got to make a better attempt at keeping up | with these threads. | | Garner Miller posted this a few days back: | 1800 is the minimum altitude; that's why it's underlined only on the | bottom of the number on the NACO charts. If it were mandatory, it | would have lines above and below (or the word "Mandatory" on Jepp | charts), and you would have to go down to 1800. | | Bob Moore |
Jim,
In particular Ed is trying to get Tim to explain why Tim thinks it is "technically illegal" to follow a glideslope down to the glideslope intercept point instead of flying level at the glideslope intercept altitude. I'm waiting for that explanation as well (though I suspect it was just some "sloppy" phraseology on Tim's part). -- Cheers, John Clonts Temple, Texas N7NZ "Jim Macklin" wrote in message news ![]() I would try to monitor these groups 24/7 but sleep and other tasks get in the way. Some posts get lost, some are snipped, some don't include any of the previous post, sorry if I post something that has been covered before. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Bob Moore" wrote in message . 122... | "Jim Macklin" wrote | | If an altitude is underlined, it is the MINIMUM altitude... | if an altitude is over-lined it is the maximum altitude. If | it is both under and over-lined the altitude is mandatory. | | Jim, you've really got to make a better attempt at keeping up | with these threads. | | Garner Miller posted this a few days back: | 1800 is the minimum altitude; that's why it's underlined only on the | bottom of the number on the NACO charts. If it were mandatory, it | would have lines above and below (or the word "Mandatory" on Jepp | charts), and you would have to go down to 1800. | | Bob Moore |
