Intercepting the ILS
Old January 28th 06, 10:05 PM posted to rec.aviation.ifr
Default Intercepting the ILS
If an altitude is underlined, it is the MINIMUM altitude...
if an altitude is over-lined it is the maximum altitude. If
it is both under and over-lined the altitude is mandatory.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
| What I'm having difficulty reconciling is the following
statements of
| yours:
| "If you can receive the G/S prior to the PFAF, it's only
advisory in
| any
| case, so you are free to use it as you choose, provided
you don't
| violate any minimum segment altitude or stepdown fixes or
any aspect of
| an ATC clearance."
| I totally agree.
| "The new CFI is technically correct but the old CFI is far
more
| practical."
| "In the case cited, the CFI is nitpicking but is
nonetheless legally
| correct."
| "I agree that the CFI is procedurally wrong, although
legally correct."
| So how can you assert these, *given that in this
instance* it is
| physically and logically impossible to "violate any
minimum segment
| altitude or stepdown fixes or any aspect of
| an ATC clearance", because
| a) the ATC clearance was to maintain 2000 until
intercepting the
| localizer, and
| b) the procedure was to descend on the glide slope to the
minimum
| segment altitude (1800) at which point the G/S becomes
primary.
| The point is that blindly following the glideslope has
the potential
| at places *other than SCK* of causing violations of
published
| altitudes. Following the G/S is not a violation per se,
busting
| published or ATC assigned altitudes is.
| The CFI is not "technically correct" or "legally
correct". What he
| could have said, after the flight, is that if one chooses
to follow the
| G/S prior to the PFAF one needs to be mindful that
published and ATC
| assigned altitudes have to be complied with, but that at
SCK that was
| not an issue.
Old January 28th 06, 11:17 PM posted to rec.aviation.ifr
Jim, you've really got to make a better attempt at keeping up
with these threads.
Garner Miller posted this a few days back:
1800 is the minimum altitude; that's why it's underlined only on the
bottom of the number on the NACO charts. If it were mandatory, it
would have lines above and below (or the word "Mandatory" on Jepp
charts), and you would have to go down to 1800.
Bob Moore
Old January 29th 06, 01:24 AM posted to rec.aviation.ifr
I would try to monitor these groups 24/7 but sleep and other
tasks get in the way. Some posts get lost, some are
snipped, some don't include any of the previous post, sorry
if I post something that has been covered before.
James H. Macklin
ATP,CFI,A&P
some support
"Bob Moore" wrote in message
. 122...
altitude...
If
mandatory.
up
| with these threads.
only on the
mandatory, it
on Jepp
| Bob Moore
Old January 29th 06, 02:01 AM posted to rec.aviation.ifr
Jim,
In particular Ed is trying to get Tim to explain why Tim thinks it is "technically illegal" to follow a
glideslope down to the glideslope intercept point instead of flying level at the glideslope intercept altitude.
I'm waiting for that explanation as well (though I suspect it was just some "sloppy" phraseology on Tim's
part).
Cheers,
John Clonts
Temple, Texas
N7NZ
"Jim Macklin" wrote in message newsPUCf.69835$QW2.2295@dukeread08...
James H. Macklin
ATP,CFI,A&P
some support
. 122...
altitude...
If
mandatory.
up
| with these threads.
only on the
mandatory, it
on Jepp
| Bob Moore
