Go Back   Home » AviationBanter forum » rec.aviation newsgroups » General Aviation
Fouled plug IO 470
Old January 28th 06, 02:11 AM posted to rec.aviation.misc
Default Fouled plug IO 470
My engine analyzed is telling me that the spark plug on the #6
cylinder, left mag is fouled. I have a new plug, but can't tell which
cylinder #6 is and whether it's the plug on the top or the bottom....
Can anyone tell me which plug it is...?
Thanks much,
Anthony
Old January 28th 06, 07:09 PM posted to rec.aviation.misc
#6 should be 3rd one back on the right (if you are standing in front of
plane, facing it). Magneto may be marked with cylinder numbers also, follow
wire from left mag to plug and that should be it. Or just check them both
while you're in there.
Thanks much,
Anthony
Old January 28th 06, 10:29 PM posted to rec.aviation.misc
That's why the information you get on a newsgroup is worth what you
paid for it.
Here's an easy way to tell the cylinders on a Continental 470. Look
at the casting and it'll say the cylinder number. As far as top or
bottom, I'll bet it's the bottom, but you should be able to see that
with your engine analyzer when you switch mags.
Get an engine manual.
On Sat, 28 Jan 2006 21:50:55 GMT, Rip
Thanks much,
Anthony
What a load of mis-information you're getting!!! Continental and
Lycoming number their cylinders differently. On a Continental, cylinder
#1 is at the REAR of the engine on the RIGHT side. In other words, in
front of the copilot on a single engine, tractor aircraft. Cylinder #2
is at the rear, on the left, in front of the pilot. Cylinder #6 is on
the left, with all of the other even numbered cylinders, at the FRONT of
the engine, closest to the propeller.
STRONGLY recommend you get the engine manual!
Rip
Old January 28th 06, 11:45 PM posted to rec.aviation.misc
It's a CONTINENTAL not a Lycoming. It's easy, the cylinder that gets there
first is #6.
"Michael Ware" wrote in message
follow
Thanks much,
Anthony
Old January 29th 06, 02:23 AM posted to rec.aviation.misc
Actually, I was thinking chevy small-block!
"Dave Stadt" wrote in message
et...
there
first is #6.
follow
both
Thanks much,
Anthony
Old January 29th 06, 06:03 PM posted to rec.aviation.misc
What a flood of ignorant information we find in these newsgroups from folks
who don't have a clue.
follow
Failed plug soxinbox Owning 10 November 6th 05 03:14 AM
Plug fouled Denny Owning 9 September 2nd 05 05:58 AM
Plug replacements for O-360-A3A [email protected] Owning 3 August 20th 05 10:39 PM
ICOM Headset Adaptor Plug Ron Wanttaja Home Built 3 June 2nd 05 07:54 AM
Clearing a fouled plug Roger Long Piloting 3 July 6th 04 05:53 AM
