Winch Launch Stresses on Vintage Gliders
Old January 29th 06, 05:41 PM posted to rec.aviation.soaring
Default Winch Launch Stresses on Vintage Gliders
Andy wrote:
Is it possible to see that one is slotted and one round holed when the
cable is ready to be hooked up to the glider?
Easy: Pull at both ends. If everything is correct, then one link is now
fixed while the other can be moved freely.
And that's the idea of the arrangement: Over time, the weak link will
stretch, even when used within its load limit, and therefore weaken. In
other words, after some time, the link will be weaker than advertised.
The second link however will keep his strengh, as it never takes load.
So when the first link breaks prematurely, the second will still hold
the advertized load.
When you pull at both ends and one link can't be moved freely under the
load, then the first link has stretched and must be changed.
Stefan
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? Bill Daniels Soaring 20 December 27th 04 12:33 AM
I need winch launch videos Bill Daniels Soaring 21 December 1st 04 06:41 PM
Aerotow with Diesel engine? Olfert Cleveringa Soaring 44 November 2nd 04 10:22 AM
Winch Experts wanted Ulrich Neumann Soaring 117 April 5th 04 06:52 AM
Underwater Gliders Burt Compton Soaring 6 November 25th 03 04:43 AM
