At night, with no horizon and no moon you have actual
instrument conditions. You can simulate instrument conditions in many ways, yellow plastic curtains and blue goggles, Foggles, a hood or just look only at the panel. There is no requirement for a hood. About 20 years ago, the FAA in Wichita came up with a device to block the pilot's view forward on the King Air 300, which required a type rating and that the pilot be able to see the entire cockpit and reach all the controls. They developed and approved the use of a sheet metal device that was held on the glare shield by a spring clamp. There were two metal pieces attached in such a manner that the pilot could not see straight ahead but allowed the examiner to see at an angle through the pilot's windshield. The co-pilot and side windows were not covered at all. Eventually, they quit using it at all. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "bsalai" wrote in message .. . | Does anyone know if Simulated Instrument Conditions is defined anywhere? | | The reason for the question is whether one can log instrument time, say | at night, when you don't look outside, but don't wear foggles or a hood? | | I can't find anything in the rules that defines simulated instrument | conditions, but since the rule for logging instrument time says both | that flight has to be solely by referenct to instruments in actual or | simulated instrument conditions, that would suggest that more is | required than "solely by reference to instruments" and therefore that | some sort of view limiting device is required. | | It would certainly be easier if they defined simulated insturment | conditions though. | | Brad |
On Sun, 29 Jan 2006 10:48:41 -0600, "Jim Macklin"
wrote: At night, with no horizon and no moon you have actual instrument conditions. FWIW, according to the old FAQ, "I agree with your statement that just because a person is flying “. . .. by sole reference to instruments . . .” has nothing to do with whether the flight can be logged as “actual instrument time” or “simulated instrument time.” Only the weather conditions establish whether the flight is in “actual instrument conditions.” And that is dependent on the weather conditions where the aircraft is physically located and the pilot makes that determination as to whether the flight is in “actual instrument conditions” or he is performing instrument flight under “simulated instrument conditions.” But for a “quick and easy” answer to your question, it was always my understanding if I were flying in weather conditions that were less than the VFR weather minimums defined in § 91.155 and I was flying “solely by reference to instruments” then that was the determining factor for being able log instrument flight under “actual instrument conditions.” Otherwise, if I were flying solely by reference to instruments in VMC conditions then I would log it as instrument flight in “simulated instrument conditions.” In your example, the flight is clear of clouds and in good visibility conditions at night over the desert with an overcast above and no visible horizon. But other examples could include flight between sloping cloud layers or flight between layers of clouds at night. These could equally meet the requirement for operations that can only be accomplished solely by reference to instruments. But, the lack of sufficient visual reference to maintain aircraft control without using instruments does not eliminate the possibility of collision hazard with other aircraft or terrain." |
"Jim Macklin" wrote in message
news:4o6Df.69914$QW2.8391@dukeread08... About 20 years ago, the FAA in Wichita came up with a device to block the pilot's view forward on the King Air 300, which required a type rating and that the pilot be able to see the entire cockpit and reach all the controls. They developed and approved the use of a sheet metal device that was held on the glare shield by a spring clamp. There were two metal pieces attached in such a manner that the pilot could not see straight ahead but allowed the examiner to see at an angle through the pilot's windshield. The co-pilot and side windows were not covered at all. We have something similar in our club's PA-28 - except we have a louvred side-window cover as well, so that if you're right next to it, you can't see out, but if you're in the other seat you can. Works very well, and is much better than those lousy foggles. Of course, there's nothing on the right-hand window; all you need there, though, is a decent-sized instructor/colleague and the view through the window can be amply blocked :-) D. |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Instrument Checkride passed (Long) | Paul Folbrecht | Instrument Flight Rules | 10 | February 11th 05 02:41 AM |
Logging approaches | Ron Garrison | Instrument Flight Rules | 109 | March 2nd 04 05:54 PM |
