We use a very similar system except the fitting is
L shaped, enough to protect the link but allowing easy inspection. It is important to remember that the weak link only works at it's rated value when new and the force required to break it reduces over the number of launches. Having the L shape protector allows easy inspection of the link for necking or elongation of the holes, both indicate a 'worn' link. In practice links are used until they break, which they inevitably will do if not changed. At 16:30 29 January 2006, Robin Birch wrote: We use a system where the weak link is held in an H channel with one end hole drilled and the other slotted so that the end bolt is supported but can pull out when the link breaks. This gives a good protection to the link. We found that the metal shrouds bent and also you couldn't see the link colour. With the H channel you can see the whole link. Robin In message , Bill Daniels writes Andy, that's a good question. Actually, as far as I know, there isn't a way to visually inspect then once they are assembled into the protective case. One wonders why. It would be easy to dip one end of the slotted links in, say, tan paint. Seeing a link assembly with two white dogbones but with one showing a tan end would indicate that the link had been assembled correctly. Bill Daniels 'Andy' wrote in message groups.com... Is it possible to see that one is slotted and one round holed when the cable is ready to be hooked up to the glider? Surely the pilot must be given the opportunity to inspect the links before accepting the cable. It's a while since I winched and we used rope weak links then. Andy -- Robin Birch |
I don't disagree that they'll eventually break, but we've made many
hundreds of launches before a fatigue. When we have broken two at a time due to a gust load, we replaced them with two new ones. Next launch we broke both again. We were launching into strong winds with a shear about 500ft. Over time we have broken the wire much more often than a weak link failure. Since we train for the proper response to a launch failure, it no longer makes much sense to use up two at a time. It does eliminate the potential for mis-assembly. Frank |
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? | Bill Daniels | Soaring | 20 | December 27th 04 12:33 AM |
I need winch launch videos | Bill Daniels | Soaring | 21 | December 1st 04 06:41 PM |
Aerotow with Diesel engine? | Olfert Cleveringa | Soaring | 44 | November 2nd 04 10:22 AM |
Winch Experts wanted | Ulrich Neumann | Soaring | 117 | April 5th 04 06:52 AM |
Underwater Gliders | Burt Compton | Soaring | 6 | November 25th 03 04:43 AM |
