Michael,
You only left out one part: when a pilot does learn to fly the PA30 and stay ahead of it, it's a blast to fly!! (especially the turbo'd model) -----Original Message----- From: Michael ] Posted At: Monday, January 30, 2006 11:54 AM Posted To: rec.aviation.owning Conversation: Whats the deal with counter-rotating props? Subject: Whats the deal with counter-rotating props? We're looking into a twin and the Twin Comanche is on our list. I know that the later models have the counter rotating props -- although i don't know too much about what this means, other than its "better". You've gotten a lot of uninformed opinions here. I started countering them, and after the first post decided it would be better to put it all in one place. I have over 900 hours in Twin Comanches of various flavors (including the CR), I've instructed in them, and I've worked on them. Having said that, here's what you're dealing with. There are exactly two things a counter-rotating prop does for you in flight. First, it relieves you of the necessity of applying right rudder on takeoff or climb. Second, it allows you to fly at a slightly lower airspeed in the event the left engine fails without rolling over - which boils down to being able to fly not just much too slow, but much, much too slow. The reality of the situation is that the PA-30 should never be flying at less than 90 mph unless (a) the runway is made and you are decelerating in preparation for the flare, in which case power is near-idle and an engine failure is irrelevant, (b) you are in ground effect accelerating after takeoff, in which case an engine failure calls for an immediate idling of the throttles and a touchdown straight ahead, or (c) you are at a safe altitude doing training. The downside is you get an engine where the prop, prop governor, magnetos, alternator, vacuum pump, fuel pump, oil pump, and tach adapter are nonstandard, and thus rarely stocked. On top of that, some of those parts are used only on that one engine (the counter-rotating IO-320) which is used on only that one airplane (the PA-30CR or PA-39) which hasn't been made in decades and of which relatively few were made. The impact on maintenance is spectacular. The reason Piper modified the original PA-30 (in many ways - they added control linkages, stall strips, and finally the counter-rotating props) was to make it a more docile trainer. They didn't succeed. If you buy the plane, make sure you find an experienced Twin Comanche instructor to train you. No amount of time in Seminoles, Duchesses, Apaches, Geronimos, or similar trainers prepares someone to fly a PA-30. I've seen what happens when someone who just took an MEI ride in a Duchess gets into a PA-30 - he can't hold on to the tail. You rarely see PA-30's as trainers anymore, and for good reason. When MEI's with 50-100 hours multi time tried to teach in them, the carnage was spectacular. You do not need an STC to convert a straight PA-30 to CR. There is a service bulletin from Piper for the conversion. All you need to do is buy the parts and convert the engine by simple parts replacement. That won't be cheap either. With the low altitudes and cool weather of the East coast, the service ceiling of the PA-30 is quite high enought (5800ft density altitude at gross). Contrary to popular opinion, the PA-30 will fly just fine on one engine, even at gross. BTDT. Most of the PA-30's out there now have been modified to reduce Vmc. The popular mod is the rudder fin (Knots-2-U and Robertson make them) which improves lateral stability and reduces Vmc. The real Vmc of a PA-30 without CR props is 80 mph. That's what was designed in and verified by flight test at Swearingen. However, that assumes you do everything right. Relatively small errors in technique can raise that. This was fixed by raising the Vmc marking on the ASI and in the AFM to 90 mph by AD (no changes were made to the airframe). If you want more info, just ask Michael |
PA30 and stay ahead of it, it's a blast to fly!! (especially the turbo'd model) You're right - I left that out. I figured that part was obvious ![]() Seriously - the plane had some rough edges, but nothing touches it for comfort and efficiency in twins, and it is a blast to fly once you get out in front of it. The turbo is OK, but the premier one is the Miller Mod with IO-360's. Now THAT is a machine. Michael |
Counter rotating propellers | Raoul | Military Aviation | 24 | September 21st 04 05:59 AM |
Boeing Boondoggle | Larry Dighera | Military Aviation | 77 | September 15th 04 02:39 AM |
Warp drive or other ground adjustable props | Wallace Berry | Home Built | 0 | March 10th 04 04:02 PM |
Props and Wing Warping... was soaring vs. flaping | Wright1902Glider | Home Built | 0 | September 29th 03 03:40 PM |
Help needed - fs2004 zaps fs2002 props | Ian D | Simulators | 1 | September 11th 03 10:20 PM |
