ANNUAL, 2005 Redux...
Old January 31st 06, 02:32 PM posted to rec.aviation.owning
Default ANNUAL, 2005 Redux... (Aztec heater)
We have heat!!!!!!!
Congrats!! Although we have a Janitrol, both heaters are fairly simple,
it just takes some patience to figure out what's going on. Am I remembering
correctly that you are in TX? There's also a well known heater shop in
Dothan AL, http://www.haroldhaskinsinc.com/pages/1/index.htm
I also need to get motivated to relace the side windows like. I need Jim
Burns for
my partner :-)
The side windows are easy and you can trim them to fit with a belt sander.
Just clean everything up real good before installing so you get a good bond
if you use silicone. Clean up the excess while it's wet, you'll never get
it off without damage if you let it dry. You can also use the original black
window seal goo. We bought LP Aero windows, 1/4 which required a 337, or
you can go with 3/16 or 1/8" and thermopanes from Great Lakes without a 337.
Old February 1st 06, 04:16 AM posted to rec.aviation.owning
Yes, I'm Austin, TX.
Matter of fact, I didn't want to mention any names, but since you
brought it up, that heater shop in Dothan, AL is the one who's
sticker is on the heater and who's signature is in the log books
as having done the last overhaul. Hopefully their work on testing
the heat exchanger for leaks was better than their work on the wiring.
Maybe the tech who did the wiring was having a bad hair day.
Everybody makes mistakes, but I would have expected those errors
to be caught during the burn and post installation test. But who knows,
maybe the heater left their shop propely wired and adjusted and the
mechanic in the field who reinstalled the heater decided he needed to
move a few wires around to make it work better.
I saved your original post about installing the side windows. I need to
tack that project. One of our windows has a crack in the inside pane.
Maybe when the weather gets too bad to fly here in Texas, I'll tackle that
project :-)
Ronnie
"Jim Burns" wrote in message
We have heat!!!!!!!
simple,
remembering
Burns for
my partner :-)
bond
black
337.
Old February 1st 06, 01:54 PM posted to rec.aviation.owning
Hey Ronnie,
I've only bought a few parts from Haskins, so I can't comment on their
repair work, but in your case it obviously wasn't done correctly, and if
they did burn test it, I agree with you, it wasn't for long enough! Our
Janitrol is some what simpler in it's operation than the Southwind, it's
either on or off, no high speed/low speed, rather it's controlled by an
adjustable thermostat. The wiring on ours is also rather simple and easy to
understand, if ours was wired incorrectly, it would never ignite at all.
My aerial applicator friend that also owns an Aztec, has all the leak
testing equipment and sealing bulbs so thankfully I am able to get ours
tested locally and without pulling it from the plane.
Jump right into that window project! It will make your entire airplane
look 20 years younger! We had them put a slight grey tint in our side
windows that adds some contrast against the white paint, making it look
pretty sharp.
"nobody" wrote in message
. com...
project :-)
Ronnie
We have heat!!!!!!!
simple,
remembering
Burns for
my partner :-)
sander.
bond
get
black
or
337.
20 Nov 2005 - Today's Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 November 20th 05 09:43 PM
2005 ANNUAL PASCO SEMINARS, BANQUET AND AWARDS PRESENTATIONS Marc Ramsey Soaring 0 November 8th 05 02:36 AM
Oshkosh 2005 Redux Jay Honeck Piloting 17 August 6th 05 07:14 AM
Oshkosh 2005 Redux Jay Honeck Home Built 13 August 5th 05 04:35 AM
Oshkosh 2005 Redux Jay Honeck Owning 13 August 5th 05 04:35 AM
