Removing original equipment
Old January 31st 06, 06:40 PM posted to rec.aviation.owning
Default Removing original equipment
Is there any reason I can't remove my factory OAT and throw it out? I
have a mechanical OAT gauge but would rather just use my EDM OAT gauge.
The JPI says their gauge is only certified as "supplemental" but does
the FAA even care if I have an OAT at all?
I've been replacing the original OAT gauge every 2 years because it's
mechanical and wears out (the needle starts to vibrate too much).
-Robert
Old January 31st 06, 06:50 PM posted to rec.aviation.owning
Possibly. You didn't say whether your aircraft was experimental or
factory-built, but for the sake of argument, I'll say that it is factory
built.
Factory built aircraft have an "equipment list" document shipped with the
aircraft showing required and optional equipment installed at the factory.
THey also conform to a type certificate. If either of these documents shows
the OAT gauge as required equipment, then the replacement has to have a
Supplemental Type Certificate if it is going to replace required equipment.
Having said that, I don't know of any aircraft that requires an OAT gauge on
the required equipment list, but then again, I haven't researched the matter
at length.
Old January 31st 06, 07:40 PM posted to rec.aviation.owning
Is your aircraft certified for know ice?
-Robert
Old January 31st 06, 09:00 PM posted to rec.aviation.owning
Just stop replacing the factory OAT and leave it....
denny
Old January 31st 06, 09:06 PM posted to rec.aviation.owning
I could do that, but I'd like to remove it because it sticks out of the
windshield, looks ugly, blocks my view, slows the plane down etc.
-Robert
Old January 31st 06, 09:20 PM posted to rec.aviation.owning
Oops, I think you may have just said the magic word. If there is a hole
drilled in the windshield for it I would not be willing to remove it and
plug the hole without an OK from my FSDO maintenance inspector. I don't
mind fooling around where I know the consequences, but losing a windshield
in flight isn't on my list of Good Things (tm) to do.
-Robert
Old January 31st 06, 09:27 PM posted to rec.aviation.owning
If there is a hole
I guess that's why we have A&Ps. To me, just a pilot, it didn't seem
like a big deal to put a plug in to replace the OAT.
-Robert
Old January 31st 06, 09:32 PM posted to rec.aviation.owning
Or did the Executive have a two piece windshield with the OAT through the
center post? Didn't the single piece come out with the 201? Good
question... good reason for not just pulling it and plugging the hole.
"RST Engineering" wrote in message
-Robert
Old January 31st 06, 10:55 PM posted to rec.aviation.owning
I have a late model Executive so its much more like a 201. I have a one
piece windshield and the OAT goes through a rather unprofessional
looking hole drilled right into the plexiglass. I figured I would just
plug up the hole, but I've never been to an A&P class.
-Robert
Old February 2nd 06, 04:14 AM posted to rec.aviation.owning
you may
have significant mechanical problems far beyond not knowing the exact
temperature.....
I don't think so, I think I"m just a picky owner. I've never flown a
rental plane that didn't have this problem. Since I fly a lot of IFR
its important for me to know 0 C vs 2 C.
-Robert
Breaking News.... (?) john smith Piloting 1 August 19th 05 02:13 AM
Equipment List Required Documentation O. Sami Saydjari Owning 9 April 21st 04 02:57 AM
Removing a Major Alteration. JDupre5762 Owning 5 March 19th 04 06:25 PM
Flying when you know there is something wrong with the plane C J Campbell Piloting 26 January 14th 04 04:38 PM
