![]() "Jeff Shirton" wrote in message ... "B A R R Y" wrote in message ... Don't believe you have much of a case for CO 2 poisoning. It is CO that is the poison!!! Apparently you never saw Apollo 13. I think what he's trying to imply is that CO poisons, CO2 simply displaces breathable air. Carbon monoxide is poisonous. Carbon dioxide is poisonous. Indeed, the distinction you are trying to make doesn't apply, since CO "simply displaces breathable air" in hemoglobin. Both can eventually kill you, but in different ways. Yes, by *poisoning* you. be your definition, water is poisonous. want to re-think your statement? didn't think so |
"Tater Schuld" wrote in message
... Both can eventually kill you, but in different ways. Yes, by *poisoning* you. be your definition, water is poisonous. First of all, it's not my definition. Second of all, *anything* is poisonous (by definition), if consumed in high enough quantities. For instance, that common poison called "arsenic" is found in your body right now. It's a poison to be sure, but it simply isn't present in toxic amounts. want to re-think your statement? Of course not. Why would I want to do that? If you don't believe me, simply do a Google search of "carbon dioxide" "poison", and see for yourself, or go to your local library, if you don't believe me. didn't think so I suggest that you might want to watch your attitude. Like I said, you can either believe me or not, you can either discover the facts for yourself, or not. Just because you don't believe it, doesn't make it any less true. Have a nice day. -- Jeff Shirton (2 Cor. 2:17) jshirton at cogeco dot ca Challenge me (Theophilus) for a game of chess at Chessworld.net! |
If you don't believe me, simply do a Google search of "carbon dioxide" "poison", and see for yourself... OK. From that Google search: http://www-formal.stanford.edu/jmc/progress/co2.html "Carbon monoxide CO, unlike CO2, is a bad poison. ... Carbon monoxide binds very strongly to the iron in the hemoglobin in the blood. ... Because carbon monoxide binds to hemoglobin so strongly, you can be poisoned by carbon monoxide even at very low concentrations..." http://www.factmonster.com/ce6/sci/A0810371.html "It [carbon dioxide] does not burn, and under normal conditions it is stable, inert and nontoxic. ... Although it [carbon dioxide] is not a poison, it can cause death by suffocation if inhaled in large amounts." http://www.prn2.usm.my/mainsite/bull...995/nst13.html "Chemical asphyxiants - Carbon monoxide, hydrogen, cyanide, nitrites, hydrogen sulphides. ... Simple asphyxiants are physiolocigal inert. ... Victims exposed to them will suffer from lack of oxygen. Carbon dioxide and methane are classic examples of simple asphyxiant. Chemical asphyxiants, on the other hand, interfere with the body's ability to utilise oxygen, They either prevent oxygen delivery (such as carbon monoxide and hydrogen sulphide)..." There are many others saying that CO is a poison while CO2 is not. -- John T http://tknowlogy.com/TknoFlyer Reduce spam. Use Sender Policy Framework: http://spf.pobox.com ____________________ |
Try searching on the terms "carbon dioxide poisoning" and
"Hypercapnia" instaid. CO2 is toxic but is nowhere near as toxic as CO. CO2 can act as a simple asphyxiant and kill by displacing oxygen or it can kill from its toxic effects. It's much more likely to kill by asphyxiation. It generally takes some unusual circumstances to encounter its toxic effects and it takes a fair amount of time for these effects to become dangerous. This is probably why it's not usually considered a poison, usually it will suffocate you long before it can poison you. CO will nearly always kill from its toxic effects rather than simple asphyxiation because there is rarely enough of it around to displace much oxygen in the atmosphere. CO2 poisoning is usually only a concern if you are breathing a canned atmosphere with plenty of oxygen but no way to get rid of the CO2. |
On 2 Feb 2006 05:06:53 -0800, "Bryan Martin"
wrote: Try searching on the terms "carbon dioxide poisoning" and "Hypercapnia" instaid. CO2 is toxic but is nowhere near as toxic as CO. CO2 can act as a simple asphyxiant and kill by displacing oxygen or it can kill from its toxic effects. It's much more likely to kill by asphyxiation. It generally takes some unusual circumstances to encounter its toxic effects and it takes a fair amount of time for these effects to become dangerous. This is probably why it's not usually considered a poison, usually it will suffocate you long before it can poison you. CO will nearly always kill from its toxic effects rather than simple asphyxiation because there is rarely enough of it around to displace much oxygen in the atmosphere. CO2 poisoning is usually only a concern if you are breathing a canned atmosphere with plenty of oxygen but no way to get rid of the CO2. carbon monoxide is about 210 times as active in binding with hemoglobin as oxygen. carbon monoxide can react out all of your hemoglobin so that no oxygen transport occurs and you die of asphyxiation. (only about 10% of oxygen dissolves in plasma and that isnt enough to keep you alive) carbon dioxide in the blood forms carbonic acid and can alter the blood pH enough to denature enzyme reactions in the body. (a lot of the enzymes are curled up long molecules that are only chemically active when certain parts of molecular loops are in near proximity. when denatured through pH or temperature they straighten out and the chemical processes they are involved with simply stop.) Stealth pilot |
![]() "Stealth Pilot" wrote in message ... snip carbon dioxide in the blood forms carbonic acid and can alter the blood pH enough to denature enzyme reactions in the body. (a lot of the enzymes are curled up long molecules that are only chemically active when certain parts of molecular loops are in near proximity. when denatured through pH or temperature they straighten out and the chemical processes they are involved with simply stop.) Stealth pilot I knew about the carbonic acid and the pH. I wasn't sure of the damage mechanism though. Very interesting. Thanks, Stealth. Joe Schneider 8437R ----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
Medal Winners: Air Traffic Control Tapes | Montblack | Owning | 36 | February 8th 06 11:16 PM |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
Riddle me this, pilots | Chip Jones | Instrument Flight Rules | 137 | August 30th 03 04:02 AM |
