Medal Winners: Air Traffic Control Tapes
Old February 1st 06, 01:58 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
Default Medal Winners: Air Traffic Control Tapes
"Tater Schuld" wrote in message
Both can eventually kill you, but in different ways.
Yes, by *poisoning* you.
be your definition, water is poisonous.
First of all, it's not my definition.
Second of all, *anything* is poisonous (by definition), if consumed
in high enough quantities.
For instance, that common poison called "arsenic" is found in your
body right now. It's a poison to be sure, but it simply isn't present
in toxic amounts.
want to re-think your statement?
Of course not.
Why would I want to do that?
If you don't believe me, simply do a Google search of
"carbon dioxide" "poison", and see for yourself, or go to
your local library, if you don't believe me.
didn't think so
I suggest that you might want to watch your attitude.
Like I said, you can either believe me or not, you can
either discover the facts for yourself, or not.
Just because you don't believe it, doesn't make it any less true.
Have a nice day.
Jeff Shirton (2 Cor. 2:17) jshirton at cogeco dot
ca
Challenge me (Theophilus) for a game of chess at Chessworld.net!
Old February 1st 06, 10:52 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
"Jeff Shirton" wrote in message
"carbon dioxide" "poison", and see for yourself...
OK. From that Google search:
http://www-formal.stanford.edu/jmc/progress/co2.html
"Carbon monoxide CO, unlike CO2, is a bad poison. ... Carbon monoxide binds
very strongly to the iron in the hemoglobin in the blood. ... Because carbon
monoxide binds to hemoglobin so strongly, you can be poisoned by carbon
monoxide even at very low concentrations..."
http://www.factmonster.com/ce6/sci/A0810371.html
"It [carbon dioxide] does not burn, and under normal conditions it is
stable, inert and nontoxic. ... Although it [carbon dioxide] is not a
poison, it can cause death by suffocation if inhaled in large amounts."
http://www.prn2.usm.my/mainsite/bull...995/nst13.html
"Chemical asphyxiants - Carbon monoxide, hydrogen, cyanide, nitrites,
hydrogen sulphides. ... Simple asphyxiants are physiolocigal inert. ...
Victims exposed to them will suffer from lack of oxygen. Carbon dioxide and
methane are classic examples of simple asphyxiant. Chemical asphyxiants, on
the other hand, interfere with the body's ability to utilise oxygen, They
either prevent oxygen delivery (such as carbon monoxide and hydrogen
sulphide)..."
There are many others saying that CO is a poison while CO2 is not.
John T
http://tknowlogy.com/TknoFlyer
Reduce spam. Use Sender Policy Framework: http://spf.pobox.com
____________________
Old February 2nd 06, 01:06 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
Try searching on the terms "carbon dioxide poisoning" and
"Hypercapnia" instaid. CO2 is toxic but is nowhere near as toxic as CO.
CO2 can act as a simple asphyxiant and kill by displacing oxygen or it
can kill from its toxic effects. It's much more likely to kill by
asphyxiation. It generally takes some unusual circumstances to
encounter its toxic effects and it takes a fair amount of time for
these effects to become dangerous. This is probably why it's not
usually considered a poison, usually it will suffocate you long before
it can poison you. CO will nearly always kill from its toxic effects
rather than simple asphyxiation because there is rarely enough of it
around to displace much oxygen in the atmosphere. CO2 poisoning is
usually only a concern if you are breathing a canned atmosphere with
plenty of oxygen but no way to get rid of the CO2.
Old February 2nd 06, 02:25 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
On 2 Feb 2006 05:06:53 -0800, "Bryan Martin"
carbon monoxide is about 210 times as active in binding with
hemoglobin as oxygen. carbon monoxide can react out all of your
hemoglobin so that no oxygen transport occurs and you die of
asphyxiation. (only about 10% of oxygen dissolves in plasma and that
isnt enough to keep you alive)
carbon dioxide in the blood forms carbonic acid and can alter the
blood pH enough to denature enzyme reactions in the body.
(a lot of the enzymes are curled up long molecules that are only
chemically active when certain parts of molecular loops are in near
proximity. when denatured through pH or temperature they straighten
out and the chemical processes they are involved with simply stop.)
Stealth pilot
Old February 3rd 06, 01:51 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
"Stealth Pilot" wrote in message ...
snip
Stealth pilot
I knew about the carbonic acid and the pH. I wasn't sure of the damage mechanism though. Very interesting. Thanks,
Stealth.
Joe Schneider
8437R
----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups
----= East and West-Coast Server Farms - Total Privacy via Encryption =----
Medal Winners: Air Traffic Control Tapes Montblack Owning 36 February 8th 06 11:16 PM
Riddle me this, pilots Chip Jones Instrument Flight Rules 137 August 30th 03 04:02 AM
