Lyc IO-360 mech fuel pump suggestion
Old February 1st 06, 08:41 PM posted to rec.aviation.owning
Default Lyc IO-360 mech fuel pump suggestion
The IO-360-A3B6 on my Mooney seems to be lossing pressure. 5 years ago
it would show 25 to 30 lbs of fuel in cruise. Now I"m getting 20 lbs
(steady, not bouncing), it also drops down to about 15 after shutting
off the electric pump for about 1 second. These values are all within
the green range but I"m wondering if I should send it out at annual.
Any suggestions on where to send it?
What should I expect to pay??
-Robert
Old February 1st 06, 08:59 PM posted to rec.aviation.owning
Don't know, but before you send it anywhere, check your gauge against a known
good gauge.
Old February 6th 06, 09:49 PM
Plaindriver Plaindriver is offline
Junior Member
First recorded activity by AviationBanter: Feb 2006
I aint sure about Mooneys, but I have a 75 Arrow, with the non turbo IO-360C1C. My FP gauge always hangs around 14-15 or so. Never see 20, 30 etc. Doesnt matter if the booster is on or not. I concur re checking the gauge.
Pik-20E Electric Fuel Pump Avron Soaring 2 October 30th 05 05:01 AM
"Out of fuel, out of hope: 'Help, I'm in the water'" [email protected] Piloting 145 May 3rd 05 11:21 PM
Cessna 172 with Wild Fuel Gauge Needle jls Owning 26 February 20th 04 05:56 AM
Christen Fuel Pump troubleshooting ShawnD2112 Aerobatics 4 August 17th 03 12:08 PM
Hot weather and autogas? Rich S. Home Built 33 July 30th 03 11:25 PM
