Another Perfect Gear-Up
Old February 2nd 06, 07:20 PM posted to rec.aviation.piloting
Default Another Perfect Gear-Up
Happened at my local airport. Listened to the whole thing online and the
archives are available at LiveATC.net (Jan 28th, KFRG, around 9AM).
Apparently a hydraulic failure. You need to be a Cablevision customer for
the news site so hopefully this direct link will work for everyone.
http://ondemand1.cv.net/news12/GLIEMELT.asx
Marco
Posted Via Usenet.com Premium Usenet Newsgroup Services
** SPEED ** RETENTION ** COMPLETION ** ANONYMITY **
http://www.usenet.com
Old February 3rd 06, 12:37 AM posted to rec.aviation.piloting
"Marco Leon" mmleon(at)yahoo.com wrote in message
It looked to me, like he got the engine stopped, just before touchdown,
also.
Jim in NC
Old February 3rd 06, 02:39 PM posted to rec.aviation.piloting
Gear up landings are no big deal for a typical GA plane. When I worked
in operations at a regional airport I was a trained ARFF responder and
none of the wheels-up landings I ever responded to involved any fire.
We'd just roll out the trucks into position and wait for the plane to
land and skid to a stop. But it still sucks for that guy with the 210 -
I guess the gear hand pump was inop? Engine teardown, new prop, belly
skins.. ouch.. Not to mention the loss of the airplane for X months for
repair. Truly a bad day, but could have been worse.
Old February 3rd 06, 05:41 PM posted to rec.aviation.piloting
If the hydraulic fluid has been lost, the gear hand pump does you no
good....
Cheers,
John Clonts
Temple, Texas
N7NZ (C210M)
Old February 3rd 06, 06:19 PM posted to rec.aviation.piloting
So if there is a system failure in the airplane (like this example), is it
the pilots responsibility for paying the repairs? Or is it the FBO who
should have been maintaining the aircraft?
This is a serious question, because I really dont know that answer and Im
curious.
John Huthmaker
PPL-SEL P-28-161
http://www.cogentnetworking.com
"John Clonts" wrote in message
good....
Cheers,
John Clonts
Temple, Texas
N7NZ (C210M)
Old February 3rd 06, 08:55 PM posted to rec.aviation.piloting
"John Huthmaker" wrote in message
nk.net...
curious.
The plane is owned by a doctor and I believed leased back to an operator. I
believe the insurance of the owner pays as long as the pilot is qualified
under the policy. In this case, I think it was the son of the FBO owner
flying. If the insurance $ is not enough to cover all the expenses, then I
think the owner can sue the pilot for the rest. Given the obvious equipment
malfunction however, that wouldn't make much sense
Marco
Old February 3rd 06, 09:28 PM posted to rec.aviation.piloting
I'm not convinced that he is going to need a new prop and engine teardown.
It sure looked like he stopped the prop before touchdown.
Jim in NC
Old February 3rd 06, 10:23 PM posted to rec.aviation.piloting
In a Navion, you wreck the prop and grind the ends off the inboard flap
hinges.
No damage to the skin - assuming a reasonable paved surface.
(The nose wheel hangs down a couple inches even when retracted.)
Geoff
the sea hawk at wow way d0t com
Spell checking is left as an excercise for the reader.
Old February 4th 06, 02:25 PM posted to rec.aviation.piloting
hinges.
You break the step off. Mine has a weld in the middle of it from
some previous owner's escapade. You also loose your antennas.
There were pictures from the "belly landing contest" at one of
the fly-ins, get a few guys to lift up a wing, prop some straw
bales under it, drop the gear, and you can roll it away.
Old February 4th 06, 05:18 PM posted to rec.aviation.piloting
Not sure why he ran away from the plane so fast. If it were my plane
I'd be right there, making sure an overzealous firefighter didn't do
anything stupid, like spray it with a high pressure hose.
-Robert
Saratoga Gear Retract Problem Yahoo! News Owning 16 November 29th 05 11:17 PM
Jet engines vs. leaf blowers 01-- Zero One Soaring 6 September 8th 05 01:59 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 05:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 03:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 06:24 AM
