As posed by the question, I agree that the belt is a distracter. However, it
is not irrelevant as the thrust applied to achieve flying speed must overcome not only the normal tire rotation friction but twice that. That the plane will fly presumes that there is enough excess thrust to do just that. -- ------------------------------- Travis "Morgans" wrote in message ... "alexy" wrote Reread the stated problem: "a conveyer belt that moves in the opposite direction at exactly the speed that the airplane is moving forward." All it is, is a trick question, aimed at testing your reading and comprehension ablility. The plane moves off in exactly the same manner as on a regular runway. The moving belt is a distracter. -- Jim in NC |
On Sat, 04 Feb 2006 16:10:16 GMT, "Travis Marlatte"
wrote: As posed by the question, I agree that the belt is a distracter. However, it is not irrelevant as the thrust applied to achieve flying speed must overcome not only the normal tire rotation friction but twice that. That the plane will fly presumes that there is enough excess thrust to do just that. So long as the bearings don't melt or seize, there's not much (if any) extra "rotation friction" at double the normal takeoff speed. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
However the airspeed-vs-wheel-rotation argument works out,
I think it is worth pointing out that all this time on the treadmill should result in a _significant_ loss of weight for the aircraft, resulting in more useful load. |
Passenger crash-lands plane after pilot suffers heart attack | R.L. | Piloting | 7 | May 7th 05 11:17 PM |
Navy sues man for plane he recovered in swamp | marc | Owning | 6 | March 29th 04 12:06 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | September 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | August 1st 03 07:27 AM |
