Gas Theft Nashua (ASH)
Old February 4th 06, 08:46 PM posted to rec.aviation.piloting
Default Gas Theft Nashua (ASH)
RK Henry wrote:
If this kind of thievery is going on at the airport, I'd be more
concerned about my airplane and its components than gas in the tanks.
A radio is worth a lot more than 5 gallons of avgas.
Unless you are flying, and it's the last 5 gallons
Old February 4th 06, 08:48 PM posted to rec.aviation.piloting
Dan Luke wrote:
"RST Engineering" wrote:
(a) You can go through the math all day long and still not explain why
I have drained the (hangared) 182 after a particularly humid day or
two and get a tablespoon or two of water in the quick drains.
I see: math is false and your charming story is proof. Very convincing.
I have one too: I've been keeping a 172RG with 62-gal. capacity tanks
outdoors in one of the most humid places in the U. S. for six years. I
never top the tanks unless I specifically need to for the next flight.
Only once in that time have I ever had water in a sample, and that was
due to a bad fuel cap gasket.
So, you've got your little story and I've got mine--so what? I'm the
one with the real numbers on his side.
My 182 was parked outside most of its life and we have fairly humid
summers here in upstate NY. I never found water in the fuel in 6 years
of owning the airplane. We used autogas and me and my partner both
tankered gas to the airplane and filled if before leaving, not after
returning. My partner had water problems before installing the flush
style gas caps, but none after that unless he pumped the water in while
fueling up. :-) I had a filter on my tank that also trapped water, but
he didn't and put some water in one time.
I think most water that gets to the drains comes in either through a
leaky gas cap or was pumped in with the gas. I don't think condensation
is a big issue. If it was, it would likely affect you more in flight
than on the ground as you climb up into cold air with humid warm air in
the tanks.
(d) You cannot explain why a hangared 150 from this airport fifteen
years ago dumped it into a pasture off the end of the runway and then
proceeded to drain two QUARTS (yes, that's quarts) of water from the
tanks.
You cannot explain why your anecdotes conflict with empirical knowledge
of the composition and behavior of the atmosphere. Come back when you
can.
Yes, I can't explain that for sure, but I'll bet it was from a leaky gas
cap, not from condensation. It would take years to suck enough air
through the vents and condense out the water to get two quarts.
However, with a leaky gas cap, this could happen in one or two
thunderstorms.
Matt
Old February 4th 06, 09:00 PM posted to rec.aviation.piloting
why I have drained the (hangared) 182 after a particularly humid day
or two and get a tablespoon or two of water in the quick drains.
Dan Luke calculated there could be 14 grams of water in 20 gallons of
air.
1 tablespoon = 15 milliliters = 15 grams
Yes. I also noted that that would be in extreme conditions. And even
if *all* that water condensed inside the tank (impossible: condensation
could not remove all the water from the air), not all of it would
necessarily enter the fuel; some would be in drops on the surfaces of
the tank that were not submerged in fuel.
(b) You cannot explain why "drain the sumps" is a daily check list
event for both fuel trucks AND airplanes.
(c) You cannot explain why CessBeePipMoo all have drains at the low
point of the fueling system. It would be a hell of a lot cheaper not
to have to put them in there. Somebody somewhere thought it was a
good idea.
Water can enter tanks in ways other than condensation.
Just so.
The condensation bugaboo is an old wives' tale. Perhaps, if an airplane
is parked for months with half-full tanks, a measurable amount of water
might accumulate due to heating/cooling respiration of the tanks, but it
might as easily be due to tiny leaks in the gas cap seals. I've never
found any in my airplane, which is parked two miles from Mobile Bay.
Dan
C172RG at BFM
Old February 4th 06, 09:51 PM posted to rec.aviation.piloting
Jon Woellhaf wrote:
I put vicegrips on the drain control to keep it
open.
I'm not puttin' vicegrips on *my* quick drain!!!
Have a good day!!
Old February 4th 06, 10:01 PM posted to rec.aviation.piloting
I have been flying for 30 years and did find excessive water in tanks
from condensation on two occasions.
Old February 4th 06, 11:30 PM posted to rec.aviation.piloting
(a) You can go through the math all day long and still not explain why I
have drained the (hangared) 182 after a particularly humid day or two and
I had the same problem after annual once. I called the A&P back and he
readjusted the cap. 5 years later, sitting outside, with never more
than 1/2 tanks, I haven't gotten even a drop of water in the tanks.
-Robert
Old February 4th 06, 11:31 PM posted to rec.aviation.piloting
You'd have to be pretty patient to drain a significant amount thru a
quickdrain.
As quick as they drain, the also unscrew, dumping the entire contents
of the tank on the arm of the person doing the unscrewing..
-Robert (who knows from personal experience)
  #28
Old February 4th 06, 11:34 PM posted to rec.aviation.piloting
Michael Ware wrote:
Sounds like good ol' pilot error to me. Somebody F'ed up and forgot to sump
the fuel system.
The question is, how did the water get there?
Peter
  #29
Old February 5th 06, 07:32 AM posted to rec.aviation.piloting
And you knew how the water got in the gas, how???
Jim in NC
  #30
Old February 5th 06, 07:38 AM posted to rec.aviation.piloting
I teach from a large fleet of Piper archers, arrows, and seminoles. We
never leave full tanks overnight, always "to the tabs", or "40 a side" in
the PA44. I've NEVER pulled water from the sumps UNLESS it rained (piper
caps leak, period). Even after a HEAVY dew, the only drops of water i've
sumped were the drops i saw drip in when i was visually checking the fuel
level (and yes i waited for them to sump out!). Have to agree that
condensation into fuel would contribute only mildly to water contamination.
Now then, fueling out away from home airport i've gotten "wet" fuel before,
but even that wasn't more then a pea sized bubble of water in the bottom of
the jar. Worst case i've ever seen was a particularly bad rainstorm in FL,
used a GATTS jar, it became a 50/50 mix of water/fuel, looked rather
spectacular. Kind of makes you wonder how much water gets into the system
when flying in a heavy rainstorm.....
That said... i NEVER even consider starting the engines unless i check fuel,
even if all i'm doing is taxiin the aircraft form one place to another,
don't want to pull a slug of water, contaminates, whatever INTO the fuel
lines for the next guy to get stuck with in the air (tho in THEORY it will
settle out into the gascolator/engine sump.)
"RST Engineering" wrote in message
(b) You cannot explain why "drain the sumps" is a daily check list event
(c) You cannot explain why CessBeePipMoo all have drains at the low point
of the fueling system. It would be a hell of a lot cheaper not to have to
put them in there. Somebody somewhere thought it was a good idea.
(d) You cannot explain why a hangared 150 from this airport fifteen years
ago dumped it into a pasture off the end of the runway and then proceeded
to drain two QUARTS (yes, that's quarts) of water from the tanks.
"Dan Luke" wrote in message
I would ten times over risk gas theft over water condensation overnight
in half-full or nearly empty tanks.
There's not enough water in 20 gallons of air to matter.
How much water is there? In *extremely* wet conditions (saturated air at
20 deg. C) there are only 14.7 g/kg of water in the air. A cubic foot of
air at SLP weighs about 34 grams at 20 C. 10 gallons is ~27 cu. ft., so
that gives about 900 g. of air and about 14 g. of water. Not a problem.
Dan
C172RG at BFM
Theft among friends bumper Soaring 8 July 29th 05 05:51 PM
Theft From Baggage-Continental [email protected] Piloting 73 April 2nd 05 08:17 AM
A-10s at Nashua, NH (ASH) today? William W. Plummer General Aviation 0 May 15th 04 04:03 PM
Good News! Arrest in plane theft case Jamie Rogers Piloting 10 November 8th 03 06:43 AM
Nashua Festival, Avidyne and WSI Doug Vetter Owning 9 September 24th 03 02:45 AM
